Green fluid leak
7th Gear
Green fluid leak
I have had my TL for just a week and have noticed a small amount of green fluid in the garage under the car each morning. I am taking it in tomorrow, anyone have this problem. Is this coolant?
A quick look at the coolant tank revealed a bright green liquid in it.
Originally Posted by havokgroup
Overflow from the reserve tank?
dsc888
Team Anthracite Member
Never seen orange coolant before.
Originally Posted by GRich4u
Coolant is normally orange these days, depending on the car. But thats what it sounds like to me.
I have in the Lexus.
There was a warning, by Road Rage probably, that you should only use Honda coolant in the TL because of the materials used in the engine and the non-compatibility with certain fluids.
No. 5 in the MID maintenace schedule is "Replace Coolant", so the MID probably won't show a 5 for the stated maintenance period of 105,000 miles, but there is no way I would wait that long. The point here is that you don't have to change coolant very often, so why not stick with the factory product, even if it is a few dollars more.
On the way!
Yeah - the coolant needs to be silicate free - which most coolants (like prestone) are not. The silicates can physically wear the aluminum coolant passages in the engine.
You change coolant so infrequently in these cars - I agree with Ron A. just use Honda coolant.
Besides - you just can't beat that beautiful emerald green color!
Weapon X
Yeah I tripped out the first time I saw the orange stuff. Then did a little research on it. It does contain silicon, and in certain engines works well, also extended the life of the hoses. On my grand Am I the radiator finally sprung a leak at 143K miles, and the hoses were still good, but had them replaced anyway.
Yeah I agree though stick with what is recommended for the car and if it needs to be changed more fequent then there is a reason for that.
The color reminds me of "The Incredible Hulk". The drink that is, hmm better watch what they put in it from now on
![Spit](https://acurazine.com/forums/images/smilies/spit.gif)
Ron:
I mean to say I have seen red/orange coolant in a few Lexus. As for myself, I always try to use factory fluids.
Originally Posted by Ron A
I have been using Havoline Extended Life 5 year protection, which is orange, in my Oldsmobile for many years, and I'm sure vehicle manufacturers are using it, or a similar product, also.
Moderator Alumnus
This one is pretty cool and simple, maybe you guys like to take a look.
https://acurazine.com/forums/showpos...90&postcount=9
Not a Blowhole
Honda Type2 coolant is green.
Besides - you just can't beat that beautiful emerald green color!![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
While coolant colors may vary, choose the one that makes you happy - BUT make sure you always use Filtered air in your tires. If you use a standard air pump at a gas station the air going inside the tires actually contains fuel vapors which, when heated, could explode. It is best to use a portable pump or air compressor with an HVC32-19A filter installed. This will avoid any potential problems.
![Fluffy](https://acurazine.com/forums/images/smilies/fluffy.gif)
7th Gear
I took it to the dealer and they said that the block heater was not properly installed by the dealer I bought it at and I should take it back there for repair.
This is very annoying. This confirms that I will not use Acura on Brant for service.
Originally Posted by Road Rage
Not true, especially on Hondas. Never seen Dex-Cool or its equivalent ever used in a Honda product.
professional TL driver
dex cool was primarly designed for GM products.... many cars can use dex cool (HONDA CANNOT) please use a silicate free coolant.... if all else fails... buy it directly from honda
SidhuSaaB
05-30-2020 12:40 AM
