Good
Old Jun 22, 2007 | 01:17 PM
waymay1305's Avatar
Good
I have an 04 TL with 53k miles on the vehicle. Vandergriff Acura of Arlington, TX is offering a free oil change with any one of the following flushs for $ 119. These include the transmission, brake fluid, power steering or carbon flushs. My transmission fluid was changed at 48K. Which of the other's do you recommend or is really necessary.
Old Jun 22, 2007 | 01:23 PM
Desert_TL's Avatar
I thought that the owner's manual specifically forbits (or at least recommends against) completely flushing the transmission fluid. However, if I was going to pick one, I'd go for a brake fluid flush. But $119 for a brake fluid flush is pretty ridiculous, even if you include a free oil change.
Old Jun 22, 2007 | 01:32 PM
waymay1305's Avatar
Good Deal or Not
The coupon or ad specifically stated it would be a flush. Do you think it's really just a fluid drain?
Old Jun 22, 2007 | 01:58 PM
94eg!'s Avatar
#1 Super Guy!
The only system I've ever seen that needed a "flush" was the cooling system. And this is only when you let your cooling system go for 150k miles or more (or mix incompatible coolants). Your OEM coolant is type-2 which is good until 120k miles. Save your money, and just get your oil changed the old fashioned way. Then buy yourself a large bottle of brake fluid & some clear vinyl tubing so you can flush that yourself. The job is simple and only takes a half-hour. You will need an assistant to pump the brakes while you open/close the bleeder valves. And make sure to use the tube-in-glass method. Any of those "one-man-bleed" kits at the auto-parts stores are cheap & a total waste of money...
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
Pegon95
Sep 15, 2015 01:54 PM
PortlandRL
Sep 14, 2015 12:01 PM
NSolace
Sep 3, 2015 08:02 PM
