Going from Drive to Reverse on the freeway...
My friend and I got into a debate the other day. Suppose you're driving 65mph on the freeway and you slam your car into reverse....I feel this will instantly trash your transmission. My friend believes that the car's internal computer will not allow you to do this and the reverse "R" on the dash will just blink until you shift back into drive. Does anyone have extensive knowledge on how the car might react in this type of situation?
Per the Owners Manual for a 2007 TL/TL-S:
http://techinfo.honda.com/rjanisis/p...707O00253A.pdf
Still not gonna try it.
Reverse Lockout
The manual transmission has an
electric lockout so you cannot
accidentally shift from fifth to
reverse instead of sixth while the
vehicle is moving.
vehicle is moving.
Automatic Transmission
Reverse (R)
Your vehicle has a reverse lockout so
you cannot accidentally shift to
reverse from neutral or any other
driving position when the vehicle
speed exceeds 5-6 mph (8-10
km/h).
Reverse (R)
km/h).
*blonde
blond is a color for wooden furniture or hair , while blonde refers to a light-haired person.
thefreedictionary.com says:
blond (adjective)
1. Having fair hair and skin and usually light eyes: blond Scandinavians.
2. Of a flaxen or golden color or of any light shade of auburn or pale yellowish brown: blond hair.
3. Light-colored through bleaching: blond furniture.
blonde (noun)
1. A person with fair hair and skin and usually light eyes. A blue eyed blonde
2. A light yellowish brown to dark grayish yellow.
blond (adjective)
blonde (noun)
I had a '99 ford ranger m/t truck that didn't have a reverse block like the newer M/T cars have and my brother decided to drive it and had never driven a stick before. He was driving down the road and threw it into reverse. Transmission did not drop but 3rd, 4th and 5th gears instantly shattered and Reverse didn't work (once he got it out of reverse). Needless to say, Transmission no longer did its job. Would not recommend it.
I used to own a AT 96 accord back in the day. One day I was driving out of my neighborhood and being the idiot I am, i was trying to change my shoes while I was driving and my elbow bumped the shifter from drive up into reverse as I was going about 20-25 mph.. Torn my transmission all to pieces. Not sure when they changed it to where it wont happen, but I know in that car it was possible.. Cost me about $1000 to get it fixed
On my TSX (5 AT), once you pass 5 mph, you can hear a little click in the shifter (that click is the lock) and it doesn't allow you to shift into reverse. And when you are coming to a stop, you hear the click again when you reach the 5 mph mark. I assume on the TL, it's the same. Except maybe you guys don't hear that little click.
I tried it on my car today and I heard a huge bang and crunching metal sound. My girlfriend was behind me and she said my transmission all of a sudden shot out from under my car and she ran over it! Now I have to buy a new trans and buy her a new bumper cover dammit
Just joking
Just joking
There's always one blonde in every crowd.
Just joking
Just joking
I've seen it happen several times. All times the trans survived and it just locked the tires. Now if I was on slicks during that pass, who knows what would happen.
One thing to think about though is how a trans brake works. It holds the car still under full throttle at the starting line by applying first and reverse at the same time. They will take a lot of abuse. I know shocking it into reverse going 60mph is a bit different than a stand still.
I had no idea the trans had a lockout above a certain mph. Good to know. I would imagine it's the same thing as the shift lock if the brake is not applied. I bet hitting the brakes would allow you to shift to reverse. Who's going to find out?
I once threw a 95 Toyota 4Runner into park while it was still moving. Heard several clicking noises until it finally came to a stop. Car still worked fine afterwards but probably messed something up a little.
OK for all interested. Since 2000 (the year the TREAD act came into place) FMVSS (Federal motor vehicle safety standards) states that at any speed above 6mph an automatic trans car must not be able to shift from drive to reverse (or vise versa). Manufactures have solved this 2 ways. 1 - Lock out the trans above 6mph, 2 - If it will allow it a switch in the trans will give a signal to stall the motor.
As for the noises heard when putting a car from drive into park. There is a small pin that pops into place in one of the gears of a transmission when it is placed into park. This is what keeps the car from moving when in park. The click noise is the pin slapping in and out of the hole when the gear is still moving. And yes it will eventually stop, and yes you can damage or break the pin or the gear.
The parking pawl is what you describe, it's a simple ratchet mechanism, looks like a large gear with a pawl that engages it. Usually at higher speeds the teeth of the gear knock the pawl back and keep it from engaging. It's just the sound of the pawl scraping the gear. It sounds terrible but it really doesn't do much damage unless it engages while the car is moving.
Many years ago, maybe 5-7 years ago. I along with my wifey, daughter, and good friend as passengers were on the 60fwy, during 5 '0' clock just before HEAVY traffic time. In a 2001 accord sedan ex. I was moving anywhere from 75mph-85mph. I was merging over quickly to avoid missing our exit. The fwy entrance before our exit was a coned off blind curve. I'd have to quickly merge over just after the cones to make my exit.
As I began to do that, I was broadsided by a car that was never there as I quadruple checked my move w/ my mirrors and visually turning my head. Anyhow it re-directed the car nose first towards the center divider. In a GOD given instant of "immeasurable talent" the counter maneuvers that followed did include driving in reverse on the fwy and slinging the car back around and into drive in a matter of seconds.
I don't know if that correlates to the discussion you and your friend held, but it is possible.
I shifted from drive into reverse with my Lexus is300 once while going 65mph. The car just kept driving fine but my reverse lights were on. Lexus computers are very smart. It knows that wasn't suppose to happen so it just kept going.
my old housemate had a bad habit of shifting into the opposite direction while the car was still moving, usually R to D.
He actually stalled it one time doing that. This is in like an 05 gen Accord coupe 4 cyl.
If it allowed you to attempt to shift to reverse, it would probably just grind. The odds of getting it into gear are slim.
The most embarrassing manual I've driven was a Pantera. Reverse pattern and no reverse lockout. I must've looked really cool when I thought it was in first but it was in second and I nearly stalled it with a ton of people watching.
