GM Synchromesh 3 questions
Hello, recently I experienced the "3rd gear problem" on my 2006 TL.
I've done the research on this board and I need to get:
GM Synchromesh Transmission Fluid Friction Modified: Part #12377916
Questions
1) How many quarts do I need?
2) Where do buy this?
3) Is there a DIY guide? I've never changed tranny fluid, I'm thinking about taking it to Firestone or Jiffy Lube
Thanks, and I apologize if these were answered before.
Questions
RBP > WDP, NBP, SSM etc
1 Post
hey man just a FYI - we have over 23852555.5 threads on this very topic - I suggest doing a search, you could've found your answer quicker!
welcome to the forums!
~Da Nocturnal Cheetah~
Questions
Questions
6 MT (manual)
https://acurazine.com/forums/ramblings-12/valentines-day-haiku-93452/
https://acurazine.com/forums/car-talk-5/omg-audi-a4-1-8t-114948/
https://acurazine.com/forums/showthread.php?t=120619
Good luck - you will love it!
347hp/300tq @ 4psi
Originally Posted by darksom1
You need just short (2.6) of 3 quarts. You can buy it at your neighborhood GM (Chevy) dealer. Here are sme DIYs:
6 MT (manual)
https://acurazine.com/forums/showthread.php?t=93452
https://acurazine.com/forums/showthread.php?t=114948
6 MT (manual)
actually its EXACTLY 3 quarts. when i drained the factory tranny oil awhile back, we poured it into a bucket, then drained it into 3 empty bottles of oil. filled all 3 to the tee.
when you drain it, jack the right side of the car up only and leave it for 15 minutes or until it stops dripping. this will gaurantee you get every last drop out.
Registered Member
It takes 2.3 quarts on a drain and fill. This assumes the vehicle is level.
This is a very simple job. Just make sure you use a torque wrench since the torque specs for the two (or three if you remove the sight plug) are all different.
Head a da Family
Originally Posted by fish008
Save yourself some cash and don't buy it at the GM stealership. Go to a place like Autozone/PepBoys and buy the penzoil synchromesh, its the exact same thing without the GM name on it.
BUT THAT IS NOT TRUE!!!
I called Pennzoil Tech Support directly and they said that is a dealer only formula. He cross-referenced the part#. Then I asked if they had something comparable, and they said they do not! Here is the number for anyone wanting to check for themselves: 1-800-458-4998.
I'd rather stick with the GM and go by what the Pennzoil rep says. A lot of people do this mod, so you have to be careful not to give out false or erroneous information.
Originally Posted by DMZ
How / where did you find that out?
If its wrong I am sorry but if you want to go out there and read what I have read feel free.
Here is another site: http://www.stealth316.com/2-pennzoil-synchromesh.htm
Acording to this link Pennzoil Synchromesh, Quaker State Synchromesh, Texaco Syncromesh, GM Syncromesh, and AC Delco Syncromesh are all the same. So before you flame me why don't you read that before just taking someones word even if they work for the company. How do you know they are right and that my "erroneous information" isn't correct?
Since it's considered hearsay, I would rather go with the guy who WORKS for the place that could stand to get money from me using their product, yet, tells me that it's not the same. He has a database of all type of the pennzoil product and works in tech support at the place in question. I like those odds vs forum threads or magazine articles even if those people are considered knowledgeable on the subject. Suit yourself, but stop being so touchy...it ain't about you or me, it's about the tranny!
Alright darksom I took you up on your offer and I called Pennzoil tech support and talked to a guy named Al; he said if anyone would like to talk with him just call 800-458-4998 and ask for Al. He said that they are actually the same and that "last I knew GM didn't have any refineries so 'somebody' must be making it for them." He also said that they are the same formula except for one slightly different mix that they use in the S-10s and other light trucks. They are all called synchromesh too and there would be some legal issues if they were not the same using the same name. Plus there may be some issue where they are not suppose to tell that they make the product for other companies as it steals sales from the others. You can see this all day long when you walk into a supermarket. You don't think that they make their own bread or batteries do you? Not trying to cause trouble, just save folks some money and you are right it is about the tranny. I will just end this right here, buy whatever you want, I don't care, just trying to educate people. Do whatever you want.
Just FYI...
Here is something which should be more helpful on the topic. I copied it from here (Sodaluvr):
https://acurazine.com/forums/showthr...=125193&page=2
"Every OEM requires either an API specification, generic specification (i.e. “Power Steering fluid”), or their OEM specification for every one of their components.
The licensing process works as follows:
If an OEM such as Honda wants to develop a special fluid for one of their components, the OEM, additive pack company (i.e. Afton, Lubrizol, Infinieum, etc), and the blender (i.e. ExxonMobil, Shell, etc) will work together to produce a finished product that’ll work in the intended application. The OEM will work closely with the additive pack manufacturer to produce an additive pack that’ll provide the necessary anti-wear protection and friction modification for the fluid. The additive pack manufacturer will then suggest a possible base oil mix to the blender, who will then blend the final product.
The blender is not required to use a specific base oil mix. The additive pack manufacturer will of course suggest a possible mix for the fluid to meet the specifications, but what the blender ultimately uses is up to them. However, whatever they decide to use, the fluid must still be capable of meeting the performance tests for that particular fluid specification.
Upon completion of the blending, since the original “three” (OEM, add pack company, and blender) were working together to develop this fluid, the blender’s final product will be put through OEM tests to verify its performance and become “licensed” for factory and service fill in that particular application.
Here’s where it gets tricky. When the OEM and the additive pack company work together to develop the additive package, they can choose not to allow licensing of the product. Of course, the company that originally developed the additive pack, and the company that blended the product you buy at the dealer, will have the licensed product as they were the original developers of the product. But, the OEM can choose not to allow the additive manufacturer they originally worked with, to sell the additive pack “recipe” to other additive package manufacturers so other blenders can buy the additive pack and blend a similar fluid. Thus, the only licensed product would be the product you buy under the automaker’s brand name, blended with an additive pack the company they worked with originally developed, and their designated blender.
However, provided that it doesn’t violate their license agreement, the additive package manufacturer or other additive pack manufacturers may produce a similar additive pack that will work in the application but of course, it cannot be certified or tested by the OEM to verify performance, as they will not license their product. This is how Amsoil, Valvoline, and Pennzoil obtain their additive packages for these various “proprietary” OEM specifications."
So you see...it can be close, but not quite the same. Just FYI...
I would get it from the GM dealer, and ASK for the "Friction Modified" Synchromesh fluid.
You should definitely check those out!
Originally Posted by KN_TL
There are also several threads on how to get better mpg and running regular gas.
Team Nighthawk Mambo King
One word of advise...please make sure to get the freeze plug off before you go and drain the tranny fluid....just in case you can't get it off, you will still be able to drive your car and not find yourself with an unable to drive it...
BTW it's a lot easier to do this if you have a CAI....
You know I may do this again as I did the change 17k ago....any comments??..
Mike's Silver Bullet
Other threads (there are many) state that GM carries 2 versions - synchromesh and synchromesh friction modified like DMZ's pic above.
Friction Modified is the stuff you need.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
12377916, amazon, fluid, friction, gm, ii, jiffy, lube, modified, number, part, pepboys, synchromesh, syncromesh, wwwgmchevydealercom
