Glovebox question
Old Jan 29, 2026 | 05:40 PM
TSX-S2000's Avatar
Question Glovebox question
My glovebox is basically loose. The only thing keeping it in place is the latch. A screw fell out of from the left side way in back. I still have the screw (self tapping) and have replaced it which fixes the problem until the screw works itself loose after a while. I was wondering if there's a metal clip missing that the screw goes into because I can't believe that a self tapping screw into plastic is all that keeps the glovebox from falling out.
The glovebox has always looked uneven (the gap between the lid and the dash has always been a bit larger on the left side) since I've had the car.
Old Jan 29, 2026 | 06:09 PM
Correlate the self tapping screw in question to the diagram below to see if any 'metal clip' is associated / present?
Old Jan 29, 2026 | 11:22 PM
TSX-S2000's Avatar
I think it's #22/23 which is "Acura 93903-24380 Screw, Tapping (4X12)" but it doesn't look like there's an accompanying clip except for possibly #20 which is "Acura 90666-S84-A01 Clip, Snap Fitting".
Old Jan 30, 2026 | 03:12 AM
mariusz439's Avatar
Just take one size bigger screw
Old Jan 30, 2026 | 05:39 PM
csmeance's Avatar
I'll see if I can get some pictures but there should be a screw on each side on the bottom, and then of course the gas/hydraulic cylinder to slow the glovebox down when you unlock it on the right hand side.
Nrp603
Jan 11, 2013 06:36 AM
curls
1G TSX Problems & Fixes
Mar 1, 2010 08:07 PM
toe222
Feb 20, 2009 07:05 PM
Diesel_Blue_TL
Jun 16, 2002 09:15 PM
SilverFleetCLP
Dec 30, 2001 08:49 PM
