Glare repair despair!
Cesspool of Knowledge
I'm sure that many (if not all) of you have noticed the haunting red glare that mysteriously appears in the rear window every time you hit the brake pedal.
Has anyone had this fixed at a dealership? My dealership replied that ther isn't any adjustment that would allow the bulb casing to move closer to the window.
Team Anthracite Webmaster
i was wondering... could you put the
1/4 inch foam insulation tape
http://www.acura-tl.com/forums/showthread.php?t=82055
from that thread... around the edges of the brake light assembly (when you have it off) and then snap it back on? it wouldnt look weird because you can't see it from the outside- its where the dot matrix is.
anyway, if anyone decides to try this, get back to us.
CEO, Team Anthracite
Your brake light cover must be off/loose. Take it to another dealer if you have to - there should be zero glare - I certainly don't have any in mine, nor any of the demos I've driven.
Originally Posted by żGotJazz?
Hmm ... that's interesting. The dealer said that all the 04TLs on their lot have the same gap between the third brake light cover and the rear window.
Let's just say that the only way I know my third brake light is working is when someone is stopped behind me and I see the red light on their faces. That's the only glare I see - on their windshield!
One of the cars I demoed when I first shopping the TL last year had the loose brake cover so I noticed the same problem. When I went back for another test drive a few weeks later, it was fixed.
Moderator Alumnus
GotJazz, not really, please check up this two threads... one of them was created by XP... check those pics.
http://www.acura-tl.com/forums/showthread.php?t=81447
http://www.acura-tl.com/forums/showp...9&postcount=81
No glare
I couldn't remove my high-mount light's cover without using a lot of force.
Would it make sense for me to try using some double-sided sticky tape on the rubber part, perhaps?
lanechanger
10-13-2015 10:56 AM
