Getting ready for our new addition
Old Aug 2, 2004 | 11:10 AM
rescueswimmer's Avatar
Well just got her spot nice and clean for our new baby coming either in 2 weeks or sometime in september in which that will be an 05
I used the rustoleum epoxyshield
This is the before. I hit it with the pressure washer then went over it with the cleaner inclueded in the kit
This is right after I finished the left side I did the right 2 days ago and looks good. You can still see some wet marks from the overlapping but this goes away in about 12 hours.
This is a close up of the floor. I addes some (SKID TEK) anti slip material to it so its not slippery at all when wet.
Old Aug 2, 2004 | 11:12 AM
indoMFP's Avatar
What your problem is?
Nice, how much was all that and how long did it take ya??
Old Aug 2, 2004 | 11:22 AM
berlinrl's Avatar
Interesting nesting instinct . . .
The kits were 49.99 each at lowes. It takes a little less than 2 kits to do a 2 car garage. 1 coat is all you need. The hardest part of the whole job was moving my crap from one side of the garage then back then back again. The reason is that your not suppose to put heavy items on the new epoxy for 24-48 hours. So I did 1 half then the other som I had to move some boxes. Id say the whole job took me about 6 hours. You first spray the floor out and clean greese and oil spots with a good oil cleaner. I used simple green since I only had a couple. Then you spray that off. Squegee the floor and use their cleaner/etching salution very mild wont kill the grass. Do the whole garage if your able. Let it dry for 12-14 hours. If everything is dry. Mix the epoxy cutin around the walls then roll in 4x4 sections sprinkle the chips if you want them if not just leave it gray. Then your finished.
Old Aug 2, 2004 | 11:34 AM
cM3go's Avatar
i see your baby will be getting a nice home and caring parents
Old Aug 2, 2004 | 11:44 AM
yano_jl's Avatar
04 5AT ABP/Camel
Nice Work Swimmer!
berlinrl, You just like it because there's a poster of three rivers stadium on the wall!
Old Aug 2, 2004 | 12:33 PM
leeherman's Avatar
Supreme Underlord/Abyss
Very nice job!
I'll probably do the same thing some day when I can afford to build a 2 1/2 car garage to replace my 1 1/2 car garage.
Regards,
Old Aug 2, 2004 | 12:35 PM
Originally Posted by yano_jl
Nice Work Swimmer!
Its actually PNC park, 3rivers and heinz field are on the other wall......
Old Aug 2, 2004 | 12:55 PM
berlinrl's Avatar
Hmm . . . I didn't even notice that!
Of course everyone knows PNC Park is the coolest park in the Major Leagues!
Old Aug 2, 2004 | 01:15 PM
yano_jl's Avatar
04 5AT ABP/Camel
I stand corrected. I wasn't sure if the poster was new enough to be PNC, so I took a guess at 3 rivers.
BTW, I didn't mean to hijack the thread. Nice job on the garage.
baelim
May 10, 2018 09:53 AM
lanechanger
Oct 13, 2015 10:56 AM
samson_420
Oct 8, 2015 01:47 AM
SeaJay
Sep 30, 2015 09:15 AM
saturno_v
Sep 27, 2015 08:13 AM
