gas saving driving styles
Originally Posted by S PAW 1
Well, after reading through all the other responses, I don't see anyone recommending unsafe driving practices. Not sure "appropriate" applies. I believe "irresponsible" is a better fit. Guess it depends upon your perspective. Let's just hope that nobody takes your advice and has an accident.
I've averaged 26-27 combined and I've gotten up to 35mpg for an out of town trip averaging a little over 65mph.
What's worked for me is accelerating moderately and backing off the gas to the minimum amount to keep the car moving the speed limit. I always accelerate hard enough not to hold up traffic but my auto usually shifts ~2,500rpm which seems lower than some posted here. If you see brake lights up ahead, let off the gas but don't hit the brakes. Depending on your speed and gear, you're now either in fuel cut and using no gas or very, very little gas. I've found that by paying attention to the cars that are 4-5 cars in front, I can coast when I see brake lights and practically never use my brakes. That's probably why up until yesterday I had at least 50% left on the OEM pads at 55K miles.
I generally save downshifting for long downhill stretches. With the reliability of the auto transmission I don't want to shift gears anymore than necessary. It does save gas over coasting in neutral.
And last, I can most certainly get better mileage without cruise control. It tends to get aggressive to keep the car at exactly the speed you set it at. On slight hills I either won't increase the pedal or just a very slight amount. If I lose a couple mph, I'll gain it back on the downhill, exceptions do exist... If the cruise sees you lose a few mph quickly it will give it a ton of throttle to make up for it as quickly as possible. On perfectly flat ground, who knows. I haven't been lucky enough to test it in those conditions. On the Buick I don't ever have to look down at the speedo on trips, I get so used to the exhaust tone that I can go an hour without looking at the speed and when I do look, it's exactly the same as before. The TL is a little more difficult because I can't hear the motor. I've accidentally been cruising near 100mph.
Originally Posted by Bearcat94
YES!!. Exactly what I was thinking of.
He drove from London to somewhere in Scotland an back. LONG trip for a single tank. Filled up at the start and made it there and back again (barely) by staying UNDER 2000 rpm the whole trip.
You do that in a TL/TL-S (stay UNDER 2000 rpm) and I bet you'd increase your range by 20%, if not more.
Originally Posted by leedogg
I was not recommending anything. It was not advice. It was a factual answer.
Live long & prosper
Our 2006 TL (AT) has averaged 28 - 30 MPH for two years. Yeah, I may be old and don't show off by racing away from lights, but there is more to it than that. You do not have to give up all the pleasure associated with driving a great car.
I can remember reading in Car & Driver, a long tme ago, that the secret is to be smooth! Get up to speed at a reasonable pace, allow space between you and the car in front, anticipate the lights, and avoid hard braking. Use cruise control and don't exceed the speed limit by more than 10%.
When on the highway, go with the flow, don't cut through traffic by getting hard on the gas and then hard on the brakes. ( Leave that style to the idiots in their SUVs.) C&D called it "Stealth Driving" and it's a good way to avoid road rage and the attention of the police.
On other thing that works for me - save the TL for your longer trips and get an Integra for scooting aroound town. Our's averages 30 - 35 MPH no matter how we drive it.
Ranger
Ranger
-I have my tire pressure at 40 PSI.
Your wet traction is also going to be reduced.
I average 25mpg (according to the MID) combined city/highway. I drive 50 miles a day, and I use the cruise control because I have a heavy right foot. From full tank to fuel warning light I get 335 miles (city/highway). I've driven from Atlanta to the first gas station on the Florida Turn Pike (I75 South) on one tank, just about 410 miles.
rockyboy
Aug 4, 2024 10:35 AM
ExcelerateRep
Dec 11, 2015 12:58 PM
