Gas Pedal Pressure
Gas Pedal Pressure
Replaced stock tires with Pirelli PZero Neros. Noticeable improvement across the board. My one comment is that it takes me more effort in applying pressure to the gas pedal with the new tires than what it took for the original tires when accelerating. My foot feels more fatigued (just call me crazy). Is this normal? Has anyone else experienced this? Is this because the Pirelli's stick more to the surface of the road? Is there a valid reason for this or am I just trippin?
What pressure are you running? You might want to add a couple of pounds to see if it makes a difference.
Did you get the M+S Neros? How was noise and ride quality affected?
Re: Gas Pedal Pressure
Is it possible you or someone else have changed your seat position?
Whatever does drive-by-wire have to do with anything? If the new tires have greater rolling resistance than the old ones (almost certainly true as you can bet the EL42s were picked, at least in part, to get the best EPAs possible) then it will take more throttle to achieve the same acceleration. More throttle = foot further to floor. If the return spring effort is at all non-linear, and, yes, the TBW (throttle-by-wire--a more precise description) has a return spring, then this would also equate to more foot force.
Originally posted by dulnev
This is even crazier than the original post! Maybe there's a 0.5%-1% difference in the amount of extra effort on the engine due to higher rolling resistance. Do you REALLY think this is detectable by the muscles in a human leg???
JK
IF the difference in rolling resistance is that small, what you say is true. What makes you so sure it's that small? Why do my new Pirellis on my CR-V at higher pressure get almost 5% less gas mileage than the original Bridgestones if the difference in rolling resistance they are creating only causes "0.5%-1% difference in the amount of extra effort on the engine"??? Where's all the extra gas going?
I'm not saying that the difference in rolling resistance is that small. The rolling resistance is only one of the forces that the engine spends power on. The other are the air resistance, friction of various components of the engine, etc. Even if there's a 5% difference in rolling resistance, the overall effect on power drainage is going to be a lot less than 5%. Just simple math...
All I know, is that tires seem to be able to make a significant (in the case of the Pirelli's now on my CR-V, about 5%) in gas mileage. The gas is going somewhere (rolling resistance is all that's left if only the tires have changed) and coming from somewhere (throttle).
SidhuSaaB
05-30-2020 12:40 AM
JDM96specCTR
10-17-2015 01:06 PM
