Garage door size
Anthracite Trend Setter
Garage door size
So I live in the northeast and have never had a garage. I recently purchased a house which has one. I never thought to measure as I thought garage doors were standardized.
Tried pulling in today during the final inspection and it was surprisingly tight. Thought a 3G TL would slide right in, not a huge car.
Opening measures about 7'11" across. Do I have an abnormally narrow garage?
Received 3,824 Likes
12x20 and 14x20
That's what Google is turning up
So at 7'11", you're 4'1" from normal size.
Stay Out Of the Left Lane
Received 1,237 Likes
I believe what Undying was giving you was the overall dimensions of a single car garage and not the door. I just went out and measured my garage doors and they are 9' wide and 8' tall. My garage is a two car at 24' x 24', which I know is a little bigger than most. The height of my garage is a little crazy as well at 13'-6." So you are about a foot narrower than mine.
Hope that helps -
Hope that helps -
8'-0" single is pretty common
my garage door has about 1 foot of clearance on each side of the car but no problem I always back into my garage.
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
3G TL/2G MDX Owner
sounds like you have one of those typical little garages in an older house. our lone garage space dimensions is 18'x10' with a 9'x7' door (this is standard door size for most garages in my area). the actual opening of the doorway itself...i don't know the exact dimensions but...let's say i have maybe 3-4 inches of space from my side mirrors to the opening. the TL is about 72" wide IIRC. it's tight getting in my garage. as far as door opening, i can get to the first stop on the door in the front...i won't even venture to test opening the rear doors (they won't make it to the first stop). we actually put a piece of foam pad for the driver's door on the wall so we don't inadvertantly whack the brick wall. the passenger side of the car has a little more space.
don't even think to put an MDX in that space. she's got another 6 inches of width on the TL. my dealer mentioned to me that they get a lot of MDX owner's coming in with busted side mirrors b/c they clipped their garage.
LOL - sideways. I'd like to see that. However I think I know what you mean.
Austin you're an idiot
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
I like turtles
In older homes a common size door is 8x7 (this is 15-20 yr old homes). On the other hand the newer homes have started to become standard at 9x7-9x8.
When I was drafting single car garage the minimum sq of a garage was at least 260 sq ft which would leave just enough for a car but not much more (im talking small boxes or a vacuum)
Keep Right Except to Pass
My TL fits in a one-car garage (townhouse built around 1992), although I do pull in slowly because the mirrors pass close to the door frame. No doubt it's affected by the snowblower being on the left side near the door so it narrows the entry a tad (this is a bigger nuisance for my wife going around from the passenger side to the door into the house as she has to squeeze past).
If a TL won't fit at all, it sounds like a REALLY narrow opening! Older house, perhaps?
I have a similar problem at my new place- the garage door itself is ok, but the concrete holding the lawn off the driveway (makes walls entering into the garage, which is subterranean) is caving in, so my UA6 has about two inches total clearance at the "squeeze point"!
I must confess I already put a nasty gouge in the starboard rear wheel arch while trying to back in just the other night. That scraping sound is soul-crushing!
09-17-2015 09:01 PM
Mugen TSX
Eastern Canada
09-16-2015 09:52 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
