Which fuses to pull to disable car?
Old Nov 18, 2013 | 07:24 PM
Yvuru's Avatar
Hi everyone,
I want to disable my car by pulling an under dash fuse. I want to pull a fuse that will do the least damage to car if anyone tried to start it.
I've narrowed it down to the DBW fuse #1, IG1 ACG fuse #18, and IG1 Fuel Pump fuse #19.
I've done some research and it seems the fuel pump would be the ideal fuse to pull, however I do not want any damage to the car and was wondering if fuses 18 or 1 will work better.
Thank you
Old Nov 18, 2013 | 07:25 PM
DaeHanMeenGuk's Avatar
disconnect the battery
Old Nov 18, 2013 | 07:29 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Are you trying to prevent it from being stolen or something else??
Old Nov 18, 2013 | 07:39 PM
Yvuru's Avatar
DaeHanMeenGuk - I do not want to go about messing with the ECU when I reconnect the battery
NBP04TL4ME - To keep it short, my dad is a terrible driver and has totaled his car. He has a history of damaging the TL whenever he drives it and I do not have it in me to take the keys from him.
Please help
Old Nov 18, 2013 | 07:47 PM
LaCostaRacer's Avatar
I'm not sure what the starter fuse number is, but I would pull that one. The fuel pump would also work, but your dad could crank the starter and kill the battery if he keeps trying to start the car. Perhaps pull both fuses ?
Your dad will eventually catch on if he can't start the car but you can. You should just tell your dad that you don't want him driving your car. Sounds like he has a history you can refer to for your reasons for this stance.
Old Nov 18, 2013 | 07:49 PM
^ The other idea is to pull the chip out of his key? That's a semi-permanent solution to the problem.
Old Nov 18, 2013 | 07:57 PM
Yvuru's Avatar
I was worrying about the battery after doing more research.
Do you happen to see the starter in this fuse box diagram here
https://acurazine.com/forums/3g-tl-problems-fixes-114/fuse-panel-layout-needed-850460/
Thanks again
Old Nov 18, 2013 | 08:14 PM
you could offer to drive him to wherever he has to go? you should sit down and have a talk with your father about this. best of luck.
Old Nov 18, 2013 | 08:19 PM
NBP04TL4ME's Avatar
I took a look at a service manual I have and if it looks like if you pull #22 or #23 in the under-hood fuse/relay box, it should disable your ignition. These are in series in front of the ignition switch. #22 is also in front of the ACC HOT in ACC II and ON III.
I have not tried this personally and this likely is not convenient as pulling one from under the dash. Please also bear in mind #22 is a 120A so be careful. You may want to start by pulling #23 first - if you want to mess with with under the hood at all.
Old Nov 19, 2013 | 03:58 PM
ATLS_666's Avatar
3 2 GONE
What ever fuse the main relay is. I did this on my old accord in order to get a free tow from CAA.
Old Nov 19, 2013 | 08:24 PM
WolfgangVonBrutal's Avatar
This is definitely the wrong way to go about this. What happens when he tries to start the car and it doesn't work? He's gonna go straight to you and ask whats wrong with it, in which case you'll have to either man up and tell him the truth instead of beating around the bush, or weave a web of lies because you can't be straight up with him.
You've also got to think about the big picture, it's not just about your car getting damaged. If he is really THAT bad of a driver, he's putting everyone else on the road at risk every time he gets behind the wheel. If his driving is as bad as you make it sound, you really should have that conversation with him about it. Just my
Old Nov 19, 2013 | 08:37 PM
erdoc48's Avatar
06 Anthracite TL
^^ Best advice of all.
Old Nov 20, 2013 | 09:54 PM
TheMitten's Avatar
8th Gear
x3. Don't dance around the root issue because all pulling a fuse will do is keep him from driving off with the car and then comes the questioning. Now I haven't been in that kind of situation, but one can assume a conversation prior to him driving your car will be better than him confronting you on why you are purposely disabling your car. Have the talk. It may be uncomfortable, but that's part of life my friend.
Old Nov 21, 2013 | 12:56 AM
ATLS_666's Avatar
3 2 GONE
This is a car forum, not a morality forum. No disrespect. All the guy wants to know is how to disable his car.
Old Nov 21, 2013 | 01:13 AM
Ken1997TL's Avatar
This is a car forum with some moral people in it.
I hope people come here to give not just technical information but possibly a good dose of common sense to go along with it. Some people on here have years of experience to share with the rest of us.
Old Nov 21, 2013 | 01:55 AM
paperboy42190's Avatar
I had the a similar idea before too. I pulled the fuel pump fuse. Whenever someone(unnamed) tried to start it, it wouldnt even crank, but the electronics would work. I figured the reason it didnt crank was that the ecu senses the fuel pump isnt working. However everytime after this happened, it would leave a CEL on the dash. A quick battery disconnect for 1 minute always cleared it though.
Old Nov 21, 2013 | 08:55 AM
Adobeman's Avatar
The DVD-A Script Guy
Sorry. I gotta agree with the camp saying don't mess with fuses and deal head on with the real issue.
Old Nov 21, 2013 | 09:15 AM
TLin401's Avatar
'13 Hyundai Sonata
Why don't you just hide the keys?
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
kuzdu
Sep 10, 2015 08:42 PM
Phambam12
Sep 6, 2015 06:57 PM
devinv1994
Sep 3, 2015 01:40 AM
