Which fuse for the rear brake lights?
Does anyone know which fuse is for the rear brake lights? My brakes don't light up when I step on the pedal. They only come on when the headlights are on but when I step on the brake pedal nothing happens. Any ideas what it might be besides checking the fuse?
This has been one hell of a weekend. First the VSA light comes on and stays on, next my horn stops working, and now my brake lights. What's next???
Are the horn and break lights sharing the same circuit? Also, if the same lights do illuminate its possible its a broken sensor on the break pedal. In the future get those fuses that glow for a few hours after they blow.
Thanks Crazymjb....actually I just RTFM and wouldn't you know it...the horn and brakes are on the same circuit. So I went outside to check and sure enough, the fuse is blown. I switched it with the same fuse for the foglights and the brake lights are working again. Unfortunately, the horn is still not working. Anybody have any ideas?
Forgot to mention, I also pulled out the fuses for the VSA and they were fine. I put them back in and now the VSA lights don't stay on anymore.
mada51589
05-03-2022 08:54 PM
