fuel system cleaner offered by sears
I was offered to have this fuel system cleaner by Sears when I asked for an oil change. Just wondering if anyone knew what I was talking about, and if it's good or not. Couldn't remember the brand name and I have been looking online and no luck yet. Thanks
B16 Swapped TL
Field Artillery rawks!
Now that thats out of the way.......... I am not sure what Sears offered you but from my experience most Oil change places that offer some sort of FI cleaner is just something over the counter you can buy at your local UhOh Zone.
With that in mind, I always bypass the offered service in favor of using Sea Foam (or GM Top End Cleaner.... essentially the same stuff) and doing it myself.
I recommend you research that product
There is a great thread floating around here somewhere.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
today I tried Seafoam in an aerosol spray can - with straw- labeled as Deep Creep
Made it really easy to do small amounts at a time, will have to add it to the DIY
Uses turn signals in my
AZ Community Team
AZ Community Team
Originally Posted by Tripnbeats
i would go to acura and dump their fuel cleaner in the car... also I have to agree the chevron tectron is sick stuff you really feel it
Champion (same as the sparkplugs) sold a similar system in the mid-90's in autopart stores (it came with adapters for various adaptors for different fuel injection systems).
yea i know about that system as well. they recently did a drip system cleaning for carbon build up and i did the throttle cleaning because 200 for a throttle body cleaning sounded crazy to me... when i can take it off and clean it myself in about an hour.
AZ Community Team
Wow! $200 for a throttle body cleaning. Amazing what dealerships charge for that.
You can remove the stock intake snout to the TB assembly, and spray TB /carb cleaner on both sides of the metal plate- a soft toothbrush or rag may be needed.
The seafoam in a spray- Deep Creep- is excellent for getting small drip type amounts added to the intake. Then you can spray some at the TB while engine running- to get the throat clean, and shoot it in vac port as slow as desired.
09-17-2015 09:01 PM
