fog lights on 05 tl
Old Jan 15, 2008 | 08:50 AM
bukjoe15's Avatar
fog lights on 05 tl
i been wantting to put oem fog lights on my car. i was going to buy the 07 grill and fog lights and put it on my bumper but i looked at it really close at the dealer but the grills are not the same.. has any one put fogs on there 05, please help
Old Jan 15, 2008 | 08:58 AM
sixsixfour's Avatar
your car has fog lights, unless you mean you want to add another pair. the switch is on the inside of your signal stalk on the left of the steering wheel column.
Old Jan 15, 2008 | 09:16 AM
blkaspec's Avatar
Full of water...
yes your car has fogs, but i have seen others use accord fogs in their bumpers, usually controlled on a separate switch. there should be some good threads if you do a search.
Old Jan 15, 2008 | 10:01 AM
bukjoe15's Avatar
yea i dont like the ones that came with it i like the ones on the bumper. i was just gonna wire the new fogs to that switch
Old Jan 15, 2008 | 05:33 PM
bukjoe15's Avatar
05 tl fog lights first attemp
ok guys i know theres alot of threads about this and i read them and i knwo you use 04 accord 4dr fogs but do you use the 4dr accord shrouds to or do you have to order a tl outer shorud. and if i use the type s honey comb grills what all do i need to purchase. im ready to do it but dont know exactly what to buy. if theres anyone located in atlanta southcarolina northcarolina or somewhere near south carolina that is willing to help for some cash pm me please
Old Jan 15, 2008 | 05:58 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
you use the accord shroud with slight modification and then you have to carefully cut the lower grill of the base non-fog light having grilles
1 aziner used the 07/08 fog light grills custom fitted looked a bit difficult
Old Jan 15, 2008 | 06:38 PM
Ron A's Avatar
Administrator
This thread has been moved from the Performance Parts & Modifications subforum to the proper forum. Please read The "Modifications" in "Performance Parts & Modifications" announcement at the top of the Performance Parts & Modifications subforum for a full explanation.
Old Jan 15, 2008 | 07:40 PM
SQUEEZY83's Avatar
Im about to do this mod next week where about do you stay if you want we can meet up and do them together.
Old Jan 15, 2008 | 10:07 PM
bukjoe15's Avatar
i live in spartanburg southcarolina i can meet up with you and watch you and help my tl type s grill wont be in until next weekend
Old Jan 15, 2008 | 10:35 PM
ggesq's Avatar
To the OP- just in case your wondering, I merged both of your threads since they're pretty much about the same topic.
Old Feb 4, 2008 | 09:14 PM
ProblemChild514's Avatar
NPB TL FTW
how can you tell he has fog lights?
Old Feb 6, 2008 | 02:52 PM
terminex's Avatar
Terminex
Because he has a TL
The Fog Lights on the 04 - 06 Tl's were next to the headlights. It was not until 07 that they put fog lights in the lower grills, and changed the wiring so that the lights between the headlights became DRL's.
If you do a search you can find the step by step instructions I did about my install using the 05 accord 4dr fog lights a couple years ago.
The toughest part is cutting the lower grills. GO SLOWLY with the dremmel. grind it down a little, then test fit, grind a little more, test fit. keep doing this. it is a pain in the A**, but the results are worth it.
Old Feb 6, 2008 | 09:28 PM
NPB TL FTW
ok so since i have drl's, then i dont have the fog?
Old Feb 7, 2008 | 10:30 AM
terminex's Avatar
Terminex
what year is your TL
I thought I was pretty clear.
If you have an 04 - 06 you have fog lights, they are simply located between the headlights. (unless like me you added a set)
If you have an 07 - 08 you have DRL's between the headlights, AND you have fog lights down below.
Old Feb 7, 2008 | 12:17 PM
aztec209's Avatar
Please
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
