FlexFuel?
Old Oct 19, 2016 | 01:09 PM
Yaseen Gabr's Avatar
3.2Seeno
FlexFuel?
So I'm wondering what it is i'll have to do to convert my car to handle e85.I'm very interested in this due to their being 7 gas stations near me that have e85 now. I found a flex fuel kit module for $399, but i'm wondering if i'll need to have a different ECU or a tune.
Old Oct 19, 2016 | 01:40 PM
you're not driving a Ford..
https://www.google.com/search?q=e85+...hrome&ie=UTF-8
Old Oct 19, 2016 | 01:58 PM
EvilVirus's Avatar
OP, have you done any research in converting it to E85?
Are you running on boost or just wanting to convert to get cheaper gas?
Old Oct 19, 2016 | 03:18 PM
Jackass's Avatar
Didn't we just go through this exact discussion 2-3 weeks ago?
There is no real point in E85 conversions unless you have the mods that would benefit from it. There are quite a few things you would need to change to make it work reliably in the TL since it was never designed for E85.
Old Oct 19, 2016 | 05:35 PM
Hi speed's Avatar
runnin a little boost
E85 requires more fuel per revolution to run the engine and would nessitate larger fuel injectors and fuel pump as well as a custom tune. The cost of those 3 items alone would negate any savings from the cheaper fuel. If you were in Argentina, it would be worth it.
Old Oct 21, 2016 | 04:14 PM
jimmyfu's Avatar
I believe E85 is a bit more corrosive too. Not sure if our fuel lines can handle running e85, or if the fuel would just slowly erode them.
