FINALLY!! Rotora BBK'd Out...front to back!!
Welcome to the club! People dont even like to drive my TL the brakes are so good in em. They say...damn dude...your car will toss you right through the windshield if your not careful! lolol
Rotora 4's w/ 2 pc. Rotors FTW!
312 HP 271 TQ Dynapack
hahaha...yeah, haven't tested em yet...still in the break-in period (almost 200 miles). Is the brake pedal supposed to be a whole lot stiffer? Cuz I think mine feels a bit soft. Bled them twice already with the craftsman bleeder gun. How did you get yours bled?
ACCURATEin, Im pretty sure that those two screws can be left off. From what I was told is there only put there during the production in the factory's, Because of the cars being over head of the people working on the cars. When I changed pads I left them off and have had no problem since.
Former Sponsor
We typically gravity bleed first and lightly tap the caliper with a rubber mallet to free up any air pockets. Then we close the bleeders and do a vacuum bleed on individual bleeders or you could use the old method of pump and release.
And I do agree....the "GOLD" Circuit Breaker pads do squeel like a MOFO! Thats what I have on my CL-S, and I had to have the shop put some "STOP-SQUEEL" on them. Nice work again man....keep it up
best rims for the money/look that you want... RonJons Time attack legends.. 18"... 21lbs i think... $250~ a wheel.. cant complain...
overall looks great..
honestly, i only had the BBK for like 36 hours, so i dont remember much, but i didnt have the 2pc rotors.. i had the 1pc kit
, I hate it cuz it makes me feel like people are thinkin, "damn, this guy needs to get his brakes checked!"...even though they're new. then again, small price to pay for WAy better brakes. What is this "STOP- SQUEEL" and where do I get it from?
Sometimes the noise is caused from the brakes not being bed in right in the beginning. Did you bed the brakes in once you installed them? You need to do a series of stops 60-5mph about ten in a row. You want to be really hard on the pedal but make sure not to engage the ABS system. The pads form to the rotors and the noise should go away. One of the cons to having such great brakes. Let us know what happens.
. it only does is at very low speed w/ very light braking ( like navigating through my driveway and slowing for speed bumps, or right before coming to a slow stop at red lights. they scream bloody murder when turning the wheels sharply when braking at low speeds. Rotora says the break-in period is 200-500 miles, (I'm like at 315mi), but I highly doubt the noise will magically go away at 500 miles. I can only hope
. Any other advice?
Update;
Squeal is only getting worse. Both fronts but more so on the driver's side...or is it cuz I'm sitting there? Nah, I think it's louder on the driver's side. It's becoming embarassing. three g's for this?
I need to get this fixed ASAP!
Hm... not like it matters THAT much but I thought I'd point it out to you that your slot directions are reversed. But it depends on the actual vents of the rotor. Cuz if the vents are facing the correct way right now, then whoever drilled/slotted these rotors did it backwards.
Or... you may have installed the rotors on the wrong sides.
I'm not sure he's on here anymore. That thread is 2 years old.
One thing to point out is that Rotora does have the slots facing differently than every other brake I've ever seen. I almost put mine on without looking at instructions which would've been the wrong way. It makes no sense to me at all but I went ahead and followed instructions. My rear stock sized Rotoras are the same way. Slots facing so that they would channel water and dirt towards the inside of the rotor instead of fling it to the outside.
I get the occasional squeek but it's maybe once a week if that. I broke mine in with several 120-5mph stops on the verge of ABS.
I got the 2 screws out easy, by putting my screwdriver in the head of the screw then hitting the handle of the screwdriver with a hammer, to loosen the screw up a little. Off they come
What's the financial damage on these? They look GOOD.
WHO RESURRECTED MY THREAD!?!?
HI, Scott!
Nope! Just a lil CRC brake grease keeps em very quiet
NBP powder coat.....FYI. I get nothing but compliments, but thanks for your input.
I'm still here! Yeah, the rotors are mounted per instructions.
Thanks for all the compliments fellas!
HI, Scott!
Thanks Allon! Yeah, 2 pistons had to go, man. I just remembered you had this front kit on your Blackura.
Do you, (or anyone else), recall if you lost some usable lenght on the wheel studs after the two piece rotors? There's approx 3/16" less stud length (I believe the rotora rotor centers are that much thicker than OEM rotors). Not a whole lot of threads lost, but it still doesn't give me a warm fuzzy. Might look into getting longer studs
Any input is appreciated!
BTW, Allon, I hate you for creeping up on 300WHP on a N/A TL!
great work, man.
.Any input is appreciated!
great work, man.i realized that i lost some usable lenght on the wheel studs too! not sure how much tho
did u end up getting longer studs?
and also does that mean our wheels are pushed out 3/16" to the fender too?
I got 2 pistons in the rear, not four. I got them just to compliment the entire kit. Not sure if they do much, since the pads are wearing super slow.
Dude that last pic is INSANE!!! PC STOCKIES FTW...ghetto
Hey have you had any issues with those black lugs backing out? I think we have the same and when i first put them on some started backing out but havent had any issues for several months.
Im partial on the Red "A" on the center caps because of the big red calipers as it kinda takes away from it but thats just my
either way
either way
Did you went 14" in the front and 13" in the back? I need to upgrade my brake to my TL. The brake on AT TL suck ass big time. I am glad you posted some picture and you made my mind. I was still on the fence because of the price
sorry I found this hilarious
Love the BBK, but the cost
