Fastbrake BBK's or Rotors and pads
I'm debating if I should just get the Fastbrake BBK's for my car, or get slotted rotors and new pads.
Any opinions? Anyone have the Fastbrake BBK's? Looks like there's an additional 10% off the sale price going on right now until 11/30th.
what do you have now- the single piston caliper on the auto trans or the 4 piston brembo on 6 speed car
For the brembos check out racingbrake brand from vendor MrHeelToe
Awesome rotors with matched pads
If you have a single caliper setup now- a 4 or 6 piston caliper will be a huge reduction in stopping distance- Wilwood are popular and well priced- see Excelerate
Remember with BBks you may have wheel-rim clearance issues and steering parts are different to allow larger rotor diameter
www.Fastbrakes.com
On their homepage it says they're offering an addition 10% off her BBK's until 11/30. That makes for an awesome price!
www.Fastbrakes.com
My Garage not
1 Post
http://cgi.ebay.com/ebaymotors/Big-B...Q5fAccessories
this should be the same company...fast brakes, revolution brakes, etc.
Fixed multi-piston calipers serve to stiffen the pedal (due to less flex) as well as even out the wear of the brake pads under extreme duty (different size pistons cause different amounts of pressure along the pad).
Remember, it's the tires that stop the car, not the brakes.
94- thats not correct, but please believe what you want~
Real Drivers dont use ABS- only morons behind the wheel would in dry straight ahead situations!!
Its made for `Stomp and Steer` in slippery conditions and making a sudden turn to avoid an accident ahead
where average drivers would lock the wheels and spin out~
Pad wear? dont get me started
how many street car brake jobs and race cars have you worked with?
things invovled in braking; shocks abilty to resit weight transfer nose dive, tires abilty to grip surface, rotor abilty to dissapate heat, pads friction component/coefficient to rotor, and clamping power of the calipers in order to generate brake torque or stopping force
Yeah if your Fred Flintstone!
I have a Front BBK kit up my sleeve for my '05 Auto and lets just say it's going to be OEM quality. Oh and it's not the TL-S Brembos or Legends. Will post pictures/results when it's all installed...
Will be using EBC Yellowstuff and Racing Brake Rotors. '01tl4tl'...I think you know what I'm talking about.
IF YOU ARE CAPABLE OF LOCKING UP YOUR WHEELS (or hitting the ABS), YOU ALREADY HAVE ALL THE "clamping power of the calipers in order to generate brake torque or stopping force" THAT YOUR TIRES CAN HANDLE!!!
I would love to hear your explanation of how ADDING more brake torque can slow you quicker when your tires are already fully loaded (ABS or not)...
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
