Engine Swap Failure
Old Mar 28, 2021 | 10:59 AM
Glorygang600's Avatar
Engine Swap Failure
I have an 05 Tl with a Honda accord Baya transmission that was swapped 2-3 years ago with no issues. I recently finished an engine swap on using a donor Honda odyssey engine (j35A6). Everything is put together fluids and all but for some reason the car wont start. It wont crank whatsoever all I hear is the sound of electricity sparking if that makes sense and for some reason I can't see what gear the car is in all though I am able to shift to all gears and I know the car somewhat registers the gear changing because when placed in reverse my mirrors move. Im at a lost for what might be the causation so far I've tried two different batteries and double checking to make sure all 4 ground wires are set. anyone with experience or insight on this issue would be greatly appreciated.
Old Mar 28, 2021 | 02:05 PM
pohljm's Avatar
jump the starter solenoid and see if starter cranks.
Old Mar 28, 2021 | 02:36 PM
start with the basics; air, fuel, spark.
Old Mar 30, 2021 | 07:07 PM
Problem Solved: Loose ground on transmission connecting to water passage
ELIN
6G TLX (2021+)
583
Feb 8, 2025 09:54 AM
Mlevy
1G CL Problems & Fixes
Nov 9, 2020 09:04 AM
routerman
1G TL Performance Parts & Modifications
Oct 12, 2012 11:59 PM
itzxharry
May 18, 2004 12:32 AM
