Engine Support Bar Attachment Points
Old Aug 20, 2016 | 02:12 PM
sbob33's Avatar
3rd Gear
What's up Azine. I am currently doing a clutch and flywheel replacement on my 08 Type S. I am using a Harbor Freight engine support bar for the job. I came across a video of Eric the car guy doing a engine replacement on a 04 TL. He was using the attachment bracket located near the power steering pump as one point of support and the other was under the throttle body/intake manifold as the second point to lift the engine out of the car.
Is the second point under the intake manifold a safe location to support the engine? It would make me nervous to use the intake manifold as I am thinking it would possibly crack or rip out the bolts. Please let me know? Thank you.
Here is the video. Its a 01:45 in.
Old Aug 20, 2016 | 07:24 PM
csmeance's Avatar
why remove the engine when you can just remove the trans OR drop the whole engine and subframe from the bottom.
Old Aug 20, 2016 | 07:50 PM
sbob33's Avatar
3rd Gear
Yes, that was the plan to drop the subframe. I have mostly everything apart. Just waiting to unbolt motor mounts and then drop the subframe. I have the engine support ready to go. Just don't know if I use the intake manifold as one point of support like in the video.
gavriil
Aug 20, 2025 04:43 PM
gavriil
Jan 6, 2025 01:04 PM
00TL-P3.2
Feb 11, 2019 11:23 AM
Mr. Showtime
Feb 8, 2016 07:27 PM
