Engine Popping Sound
Old Jun 4, 2005 | 10:55 PM
SpiderWayne's Avatar
Sometimes when I first start my 2005 TL I hear a popping sound. Sounds like its coming from the engine area.
Anybody else hear a popping sound?
Old Jun 5, 2005 | 02:53 AM
tyrael's Avatar
goodbye RL for now...
I just started noticing that too! anyone help?
Old Jun 5, 2005 | 10:36 AM
Heidi's Avatar
Popping is Normal
It does the same on mine. I read in the Forum somewhere that this is from the engagement of the ABS so it is normal.
Old Jun 5, 2005 | 07:31 PM
pettydw's Avatar
If set in "Auto" climate mode, the A/C compressor will start about 2 seconds after the engne, sometimes with an audible clunk.
Old Jun 5, 2005 | 08:58 PM
mbwmn's Avatar
there is a "grinding" noise/vibration that can be felt mostly near your right foot usually w/in 10 seconds or 20ft of starting to roll forward. this is normal. it is the ABS brake pump cycling. there are multiple threads regarding this. try the 3g garage...
when does your popping sound occur? (cold-start, after idling for several minutes, while driving a certain speed????)
why are you under the impression that it is an engine sound? does it change frequency when engine speed changes? does it only happen when siting still w/ the engine running?
we need more details to diagnose your vehicle over the net!
Old Jun 6, 2005 | 12:24 AM
The popping seems to only be when starting the car cold and there is a "grinding" noise/vibration that can be felt mostly near your right foot usually w/in 10 seconds or 20ft of starting to roll forward.
Its the ABS? If this is normal then côôl
Old Jun 6, 2005 | 02:24 PM
JPSMAN's Avatar
its normal...........
Old Jun 6, 2005 | 02:40 PM
ericajackhannahjamie?'s Avatar
It is normal SpiderWayne, that is the sound of Acura TL ABS engaging itself. Usually happens when a car is rolling about 5 to 10mph.
Old Jun 6, 2005 | 04:18 PM
Thanks, I'll Ignore.
ôô
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
