Engine Idle Problem
Engine Idle Problem
1) when my TL is cold (65-70F) and i start it, if i hold the tach at 1200 rpm i get a rough idle. considering the whole thing is computer controlled i would not expect this.
2) after the car comes up to temp and then i park it, starting it takes lots of cranks.
my TL is a AT with only 1620 miles on it.
anyone else experiencing issues like this ???
Originally Posted by xristos
Why would you hold the tach at 1200 rpm?
.:HALCÓN DE LA NOCHE:.
Maybe because the engine is warming up, but it should feel different when it is actually in drive. I wouldn't rev up the engine while its warming up.
If you experience starting takes a long time its due to the ULEV system. Its mentioned in the forum.
Originally Posted by need4spd
I used to have to crank the engine 3-4 times sometimes to get it to start, what a bummer.
if i hold the key long enough it does start, just seems very long for this TL.
Shift_faster
Originally Posted by cvajs
was there any fix done by service ???
And yes, I concur with your observation that the engine can seem a little rough at that rpm. I have the 6MT, but I have felt it if I rev the engine (in neutral) and as the revs pass through that range on its way down, there is some vibration.
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
