Eliminating Hyperflash
Old Mar 28, 2013 | 08:23 PM
TotalTL's Avatar
hello my fellow Acuraziner's,
I have looked around and have seen several detailed DIY's on how to install load resistors. When I did it myself I followed the DIY exactly and I still have hyperflash in the front turn signals. One end of the resistor was tapped into the turn signal wire(red/blue wire driver side+ white/gray wire passenger side) and the other was to what I thought was the ground wire...a black wire with gray lines located close to the turn signal wire. If anyone could post a pic of which wire is the ground wire I would be filled with eternal joy. (I know its the fully black one but idk which since there are a few) I own a 2004 TL 6 Speed btw. Thank yaaa
Old Mar 28, 2013 | 08:36 PM
The Machine's Avatar
Registered Member
This way is MUCH simpler than having to wire in the load resistors you are using.
https://acurazine.com/forums/3g-tl-2004-2008-93/g-109-diy-eliminate-led-bulb-induced-hyper-flashing-without-load-resistors-815219/
IamaTL's Avatar
I like turtles
Just do this, its better and easier.
https://acurazine.com/forums/showthread.php?t=815219
edit: Machine beat me to it, but ill leave it.
Old Mar 28, 2013 | 08:43 PM
paperboy42190's Avatar
^+1 its a much better method
Old Mar 29, 2013 | 04:52 PM
TotalTL's Avatar
yea i saw that one yesterday. i figure ill just do it since its simpler, but can i just remove the resistors and put electrical tape over the part of the wire i tapped?
D-Rob
62
Jan 5, 2016 11:44 AM
KBTypeS
25
Oct 1, 2015 04:49 PM
Sep 17, 2015 09:01 PM
nishant11
Sep 2, 2015 10:34 AM
