Eliminating Hyperflash
hello my fellow Acuraziner's,
I have looked around and have seen several detailed DIY's on how to install load resistors. When I did it myself I followed the DIY exactly and I still have hyperflash in the front turn signals. One end of the resistor was tapped into the turn signal wire(red/blue wire driver side+ white/gray wire passenger side) and the other was to what I thought was the ground wire...a black wire with gray lines located close to the turn signal wire. If anyone could post a pic of which wire is the ground wire I would be filled with eternal joy. (I know its the fully black one but idk which since there are a few) I own a 2004 TL 6 Speed btw. Thank yaaa
Registered Member
This way is MUCH simpler than having to wire in the load resistors you are using.
https://acurazine.com/forums/3g-tl-2004-2008-93/g-109-diy-eliminate-led-bulb-induced-hyper-flashing-without-load-resistors-815219/
yea i saw that one yesterday. i figure ill just do it since its simpler, but can i just remove the resistors and put electrical tape over the part of the wire i tapped?
D-Rob
62
01-05-2016 11:44 AM
09-17-2015 09:01 PM
