EL42 Pressure check
EL42 Pressure check
I am curious what you guys are running your tire pressure at on the EL42's. Is says not to exceed 40psi...is this cold? I cant tell if I am getting any cupping and they are wearing evenly, but I am running mine at 31psi. Just curious...thanks.
Re: EL42 Pressure check
My garage is around 45 Fahrenheit, and my EL42s are 39/35, high-speed standard.
Since our weather is usually around 15-35 recently, they should be around 36/32 and 38/34 while parking outside. Anyway, I won't let my tires' cold-pressure stay above 39/35 when temp is going up.
Also, I always believe a little higher front-tire pressure could help to adjust FWD understeer issue, IMHO, I would never have four tires with the same PSI. (not intend to offend against anyone here)
SidhuSaaB
05-30-2020 12:40 AM
HeloDown
09-08-2015 06:51 PM
