DVD-Audio Support
You need to use -R disks, I know that for sure. But I am not sure if it will just work straight away - I think there is special software you need to get to burn DVD-R to play in the TL. Do a search, there are a lot of threads on this.
Cvajs,
You will definetly need software to properly "author" DVD-A also known as DVD-Audio discs. Right now the only one that the majority of us consumers could probably afford is a product from Minnetonka software called DiscWelder Bronze @ 99.00. You can read more about it here:
http://www.minnetonkaaudio.com/news/...derBRONZE.html
Also, the large culimation of searching through this forum, as MikeyK states, you'll need to use DVD-R media.
To use your music files with Discwelder, you need to have them in .wav format.
Good luck.
Good luck.
yes, i have Minnetonka Bronze for authoring dvd-a discs. i use NeroExpress to rip cd's into 48khz/24bit PCM files. i have not tried the task of ripping from a dvd movie the 5.1 audio into 5.1 PCM, perhaps at a later time i will try that.
just wanted clarity on what type of "dvd format" the tl cd player can read.
thanks for the info...
Acutally, with DiscWelder, you'll need a different program to convernt mp3's to .wav. (Unfortunately DiscWelder doesn't do it). You can find a number of free programs to do it at www.downloads.com...
Originally Posted by GunnmeTaLCURA04
so with this software i can get my current mp3 files, convert them to wav's and then it will transform these to 5.1 sound? on DVD discs?
Howerver you cannot upmix your "stereo" mp3's (or other formats) into 5.1 surround. Technically you could perform this, howerver my guess is that it would require specific software which probably costs quite a penny, in that most of the low-end consumer stuff is in "stereo" format.
Also, so you know, if you have any .wav's or other already mixed in 5.1, when transfered into DiscWelder Bronze, they will retain the 5.1 surround.
you need a source that has 6 (5.1) channels in it in order to make a 5.1 dvd-a disc.
you can rip audio in 5.1 pcm encoding from any dvd movie disc, then the 5.1 pcm can be used to make a dvd-a disc...
http://forum.doom9.org/showthread.php?threadid=60137
Mike
Originally Posted by TLPatriot
Can I rip stereo MP3's to a DVD-R disk and then enjoy the benefit of greater storage space than on a CD-R?
The beauty with Discwelder, is that you can put 99 songs in 1 group. However I believe that the TL only recognizes group 1, so you'd get 99 songs worth of play time (providing you didn’t burn up all the disc space) on one DVD.
Originally Posted by svtmike
Actually, there is freeware out there that will do this. Here's a link to a guide:
Mike
Mike
navtool.com
31
11-16-2015 08:30 PM
ExcelerateRep
10-14-2015 08:20 AM
4drviper
09-23-2015 07:42 PM
