Dumb question - Trunk
I hope someone can help me solve my dilemma. I am planning to buy the trunk tray and was wondering if I can have both, tray and cargo net. If yes, will it require any modifications to the tray?
The reson I am asking this dumb question is that I saw two different trunk trays, one with bumps over the net hooks and one with out it. Which ones are you guys using and how does it work.
https://acurazine.com/forums/showthread.php?t=65547
If you're using the TL trunk tray, you will probably have to follow the directions on this thread.
LOL! I tried this as my car has a trunk tray and the net.. after about 5 minutes it looked like something you would use to hang a bundle of bananas.. soo this really helped thanks fo r the link blacktls07!!
I have both. Make small slits in the tray to get at the mounting knobs for the cargo net then fasten the net as shown in the above link by 'blacktl07'. You can buy the tray for $77.88 at http://www.handa-accessories.com/tl.html.
Don't have to CUT the Trunk Tray
The buttons for the cargo nets screw out of their sockets, and the screws are pointed. After removing the 4 floor buttons, place the trunck tray so that the circles are over the holes, and use the screw attached to the button to poke a small hole in the center of the circle while it is positioned on the trunk floor. They screw in nicely, and you have a clean and relatively waterproof installation.
Only inconvenience -- when you need to get to the spare tire you need to temporarily remove the two trunk floor buttons closest to the truck opening. But how often are you going to need the spare?
Puma Jim
09-26-2015 01:08 AM
wusty23jd
09-24-2015 11:41 AM
