DRL upgrade kit from V-Leds
Old 03-10-2009, 05:52 PM
  #41
One or Two?
chuanger's Avatar
Originally Posted by DNPhotography
Looks like we have a winner-winner-chicken-dinner!
Old 03-10-2009, 06:04 PM
  #42
Unregistered User
chairguru22's Avatar
It is pretty hard to see during the day... I guess that's why they are usually yellowish, but I hate the yellow look... ah o well...
Old 03-10-2009, 07:06 PM
  #43
Bone stock tl-s
jptl04's Avatar
cool DNPhoto, do yo have the 68 SMTs? i would like to see what that looks like. i have those but took them out. i now have the nokya hyper yellow bulbb in there looks pretty good. and bright yellow as hell.
Old 03-10-2009, 07:21 PM
  #44
Photographer
DNPhotography's Avatar
i had them but one wasnt working. so i sent them back. VLEDS is awesome! awesome customer service. anyways i got confirmation from them that this harness does work. well i should know im running them now. but as i said it is not with the 68 SMTs. i was also running the Nokya yellow bulbs and they are great. with the 68 SMTs it should be really bright.
Old 03-13-2009, 02:28 PM
  #45
New shoes on my
mglax13's Avatar
I just got my 68 SMT's in the mail and the harness. I will install today and take photos.
DNPhotography, which side did you plug in the resistor and which side did you plug in the bulbs? I'm thinking resistor in the pax side and bulbs in driver side.
Old 03-13-2009, 02:54 PM
  #46
Photographer
correct! and psot pics!
Old 03-13-2009, 03:31 PM
  #47
New shoes on my
mglax13's Avatar
I definatly will. I get out of work in 1 hour and 35 minutes. I can't wait to get home and put these in. They've been sitting on my desk all day staring at me
Old 03-13-2009, 03:35 PM
  #48
One or Two?
chuanger's Avatar
Hurrrry! I can't wait either!!!
Old 03-13-2009, 07:02 PM
  #49
New shoes on my
mglax13's Avatar
Grrr, I just got home from work and now it's dark and cold out. I'm debating doing it tonight. Tomorrow I'm out of commission too all day...this might have to wait til Sunday...
Old 03-13-2009, 07:07 PM
  #50
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
Nokya Hyper Yellow DRL's FTW!
Old 03-13-2009, 08:16 PM
  #51
One or Two?
chuanger's Avatar
TEASE!
Old 03-13-2009, 10:25 PM
  #52
New shoes on my
mglax13's Avatar
Originally Posted by chuanger
TEASE!
Ok..FINE!! I hate a tease...so I went out in the cold and dark and installed them...
Here is what I got from V-LED's
68-SMT LED 9005's. Looks to be well put together from what little I know.
Resistor for pax side light
DRL Harness
Driver side connection
The harness looked like it was pretty well made too. The only complaint I have is the connector for the passenger side, the wires move in and out of the female plug a little too easily and it was resulting in a lost connection. I jammed them all the way up in there and taped it up and it was all good.
So... lights before (sorry for teh terrible pic, but you all know what they look like )
Lights after - They look more blue in the photos than they are in real life.
With the flash on...looks a little more like this
I'll get some day time photos tomorrow. Install took all of 25 minutes, mostly because I was fighting with the pax side OEM bulb. Light output is equal from both side, and I got no DRL light on my dash
All in all, I'd say this was worth the $70 considering it's our only option.
Old 03-14-2009, 12:07 AM
  #53
AZ Community Team
Bearcat94's Avatar
Received 7,771 Likes on 4,342 Posts
And just to confirm for me ('cause I'm slow on these things): NO DRL dummy light, right?
Old 03-14-2009, 12:20 AM
  #54
New shoes on my
mglax13's Avatar
That is correct sir. Negative on the NO DRL dummy light.
Old 03-14-2009, 12:22 AM
  #55
AZ Community Team
Bearcat94's Avatar
Thanks. I'm going to have to get these, I think.
Same time as I get the flat 24 LED domes I guess.
Old 03-14-2009, 01:28 AM
  #56
One or Two?
chuanger's Avatar
Haha, thanks mglax!! Great pics and exactly what I've been looking for. I really do appreciate you slaving away in the cold! I'm gonna have to pick this up as well! V-leds ftw!
Old 03-14-2009, 02:13 PM
  #57
Photographer
haha yeah thanks mglax13 for installing them in the cold! technically these would also work for HIDs as well.
Old 03-15-2009, 12:52 AM
  #58
Manchester United 4 life
type-sowner2007's Avatar
Originally Posted by rockyfeller
OK nevermind I just figured it out. It steps up the DRL low voltage input to a full full 12V voltage perfect for you 07+ guys so you can run your LEDs at full brightness. You could actually run an HID kit off your DRL outputs with that module too!
hey rockyfeller, with this module you would be able to run an LED strip off the DRL's as well wouldn't you? Just like on the new Audi's??? I wanted to wire some LED strips to the DRL's but the DRL's only run at 6.4V, this will cure that I hope
Old 03-15-2009, 03:45 PM
  #59
New shoes on my
mglax13's Avatar
I don't think this changed the voltage on the DRL's, it just makes the voltage distributed to each side even.
Old 03-15-2009, 06:47 PM
  #60
thanks for the input mglax, I'll just have to find another way to bump up the voltage for the DRL's so I can wire my LED strips into them.
Old 03-15-2009, 07:36 PM
  #61
New shoes on my
mglax13's Avatar
Well if the 6.4V is enough to light up these 2 bulbs, then I'd think that maybe it's enough to light up the LED strips IF you only lit the LED strips and didn't light any bulbs. In that case, I probably wouldn't bother going with that specific harness from V-LED's. I think I'd do something similar with a resistor on the passenger side, and then splitting the power on the driver side.
Old 03-15-2009, 08:01 PM
  #62
mglax thanks for your help, I actually ordered the harness set so I can swap out my current DRL's. This set only comes with one harness and one resistor right? So maybe I could just run this http://www.v-leds.com/Exterior-LED/D...01806-1-3.html on the left side and run the other harness and resistor on the right so that I could have my DRL's and the LED strips lit.
Old 03-15-2009, 08:20 PM
  #63
New shoes on my
mglax13's Avatar
That sounds good to me, but don't take my word for it becasue I don't know a whole lot about the electic system as it pertains to the DRL's. I'm just speculating. LED's require very little power to run, so who knows, it might work. Trial and error is my method of choice with these things...lol
Old 04-22-2009, 01:02 PM
  #64
One or Two?
chuanger's Avatar
Update to this thread. The harness works perfect, there is no DRL warning light on the dash, however the output of the actual 9005 LED DRLs is about half of what they should be. If you look at the output of the LED DRLs during the day, they are not very bright at all. They seem to be quite a bit dimmer than the oem 9005 bulbs.
I spoke with Jake and he said purchasing the plug-n-play 9005 in-line DRL module and installing one on the harness side will yield a full 14.5v to the LED DRLs. I'll post some pics when I get this.
link to the module: http://www.v-leds.com/Exterior-LED/D...-p6297704.html
Old 04-22-2009, 01:09 PM
  #65
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
Ok forgive me, if these aren't outputting the same amount or more light then stock, whats the point again?
Old 04-22-2009, 01:11 PM
  #66
ADVANCE.
J-STEELE's Avatar
Sorry, has nothing to do with the topic but your car looks happy and cozy in the garage... haha... Nice n clean...
PEACE!
Old 04-22-2009, 01:14 PM
  #67
TeknoKing's Avatar
The original DRL via V-LED that were available...showed the same characteristics of brightness in the beginning...after two weeks of riding with them...they die...and are no longer as bright as before... I think it would work better if the DRL produced a nice yellow output or a deep yellow like Hoen Endurance bulbs.
I'm a skeptic... I need to rethink making another $50 commitment. To people who have them right now, please continue to post your updates. Thank you.
Old 04-22-2009, 04:05 PM
  #68
BASISON's Avatar
I bought a set of these for my wife's 2009 Honda Pilot and all they did was keep blowing the DRL fuses. I even brought the fuse up to a 20A and it still blew them. I guess they look great if you can get them to work.
Old 04-22-2009, 04:10 PM
  #69
Photographer
very true. i had these on for a few days then changed them back to my Nokias because i wasnt happy with the output. but i didnt try using the plug and play harness (which i have). ill give that a try today.
its an aesthetic mod i guess.
PEACE!
haha thanks.
Old 04-22-2009, 04:54 PM
  #70
One or Two?
chuanger's Avatar
Let me know how it goes.
Old 04-22-2009, 11:32 PM
  #71
so with this plug and play module, you do not need to have the load resistor for the module above correct?
Old 04-23-2009, 07:03 AM
  #72
A Happily Modded TL-S
blue rocket's Avatar
ive had my VLED DRL's for over a year and they are as bright and perfect as they were day 1. Never had a DRL dash light either.
Old 04-23-2009, 04:12 PM
  #73
NOTSKERDD's Avatar
I've had my piaa's for over a year- no problems whatsoever.
Old 04-23-2009, 05:41 PM
  #74
New shoes on my
mglax13's Avatar
Keep us updated, I'd love to see how this works. I noticed too that the LED's aren't super bright during the day as well. If I look at it head on, I can see the reflection of the LED's in the reflector part as individual dots, so I always assumed that it wasn't bright due to the fact that it was day time. If this will boost the voltage and make it really light up, then that would be awesome!
Just out of curiousity (I have no electronics knowledge), how can you just step up the voltage like that? Wouldn't it require more power coming from somewhere?
Old 04-23-2009, 06:12 PM
  #75
Photographer
i forgot i sent my DRL modules back. sorry.
Old 04-24-2009, 04:31 PM
  #76
2008 tl-s sleeping in
mmp1214's Avatar
how come my harnesses are so much smaller then the ones that you guys have? the ones i have don't work either, they came with a harness with like a mini ballast on the end of it i don't know how to even describe it.
Old 04-24-2009, 05:15 PM
  #77
One or Two?
chuanger's Avatar
Ok so I received the 9005 in-line module and plugged it into the harness side and the DRL LED output actually DECREASED by about 2x. So in short, it doesn't work. The standard harness is about as much power as you're gonna get for the LED DRLs at this time. Sucks! I guess i'll be going back to my Nokya yellows.
Old 04-24-2009, 05:16 PM
  #78
One or Two?
chuanger's Avatar
You are referring to the in-line modules. The harness is this....
http://www.v-leds.com/Exterior-LED/D...-p6901806.html
Old 04-24-2009, 05:32 PM
  #79
jrtls03's Avatar
thanks for posting this. i just got mine in the mail today from v-leds but based on thread I don't think I'll be installing them. I may go for the nokya yellows but i need to find some pics of them first.
Old 04-26-2009, 09:58 PM
  #80
THTL's Avatar
Can someone please help me? I have an 05 TL, with 07-08 type-s headlight. I also have the DRL module that i bought from autobarn.com. I want to get the 9005 DRL LED(amber), do i need to get the 9005 DRL WIRING HARNESS + RESISTOR or the 9005 PLUG N' PLAY DRL DAYTIME RUNNING LIGHT MODULE to make it work?
thanks.
Quick Reply: DRL upgrade kit from V-Leds
