Driver's seat cover (bottom) replacement....
Wondering if anyone here has ever gone through the process of replacing their lower Driver's leather seat bottom?
If so, how much was it, and how many hours labor did they charge you for the dealer to replace it?
Any input appreciated.
Dan
I was also looking at these guys as an option.
http://www.youtube.com/watch?v=GlwSLpdRw3I
Dan
No, a regular 2005 Acura TL. Wondering how much the seat bottoms / tops cost from the stealership?
it will cost you an arm and a leg and maybe your first born's arm and leg.
go to a junk yard, go to car-part.com, or go to an upholstery shop that specializes in perforated leather . Before I bought my TL from a dealer (Used), they contracted a guy to come out and replace the cracked leather bottom. It looks and feels great, much more supple than the OEM leather.
Unfortunately the OEM leather looks like it sucks and wears out quickly. My 23 year old Audi leather is still soft and supple.
Big difference in quality of materials. Looks like the Acura got the same Honda supplier. Looks good when new but doesn't last long.
What is this "endless rpm" kit?
I'd see if you can find an upholstery shop near you. I had my car tinted at a place and the heater they used in the back of the car burned a hole in my back seat. The owner had me to go an upholstery shop and the guy there was able to match the color and leather exactly. I'm sure it wasn't cheap but it was probably cheaper than the price tag on the entire rear seat cover.
I ended up having to buy a new seat cover for my drivers side because the foam padding was worn away as well as the leather. Had the same shop do the install for $90 and it looks great. My passenger seat now is ripping so I am going to have to take that in sometime and get a quote.
Do you have any pictures of repairs or seat bottom replacements to show for TL? Sounds like a good alternative.
Is there any warranty on your product?
I just found this video on YouTube which shows all the options and a completely new installed interior in an 04-07 Acura TL. Looks pretty impressive and I like the blue accent stitching the owner selected on that A Spec.
The seat kit looks pretty darn nice. I think their base kit is only like $450-500, so that's a good option for those with pretty warn out interiors.
Just had both bottoms and armrest with padding done.07 MRP Type S taupe interior.Small custom auto upholstery job in north jersey.They look and feel great.Paid $500 cash.Think it was a great deal.
Ive replaced both bottom cushion skins with leather from autocustomleather, the match is pretty much perfect and the fit was very good. i think they look better than the custom job posted above (no offense). Its a bit of a process, especially the first time, but its really not hard to do. i have found it is much easier to use zip ties in place of most of the hog rings.. easier to install, easier to cut and remove if needed, and pulls everything tighter.
I had replaced cloth covers on integra seats before, but thats it. i kind of used some hog rings in certain spots and zip ties in other.. its really pretty easy and self explanatory, as when u remove the old cover you will see just how everything is attached. removing the seat from the car (without scratching anything) and disassembling the seat takes a while.. replacing the cover will take a little while for the first one, the 2nd one will go much smoother. just try not to rip the rods (that the hog rings attach to) out of the foam.. that will leave you with covers that might not be fully tightened into place
Head a da Family
Hey guys - I went through the same issue here recently on my 2004 TL - Moon Gray Interior. I opted to buy the OEM seat replacement for my driver's side seat through Acura Parts | Genuine Acura OEM Parts | Acura Parts Cheap and I'm very happy with the results. The install wasn't too bad, but I definitely agree that it's helpful to use zip ties as noted above. See a few pictures attached.
Let me know what you think.
Thanks,
Andrew
Thanks,
Andrew
iWhine S/C 6MT TL
My wife ordered me a 100% full leather kit from , leatherseats.com. I have pictures posted in my build thread. I haven't done the install yet. The quality and detail work is top notch! Worth every bit.
Yeah, I didn't see the S-Type as an option on their site either, but they do some pretty sweet custom setups. There's another video (attached below) where they use alacantra inserts, custom colored stitching, etc...
https://www.youtube.com/watch?v=DKZz...ature=youtu.be
I think I'd need to find a nicer car before I invested in this, but I think your interior would look like new with one of these interior kits. It's a WAY better deal than the factory seat cover options IMHO.
You could get all the seating surfaces replaced through this source for less than you could replace the front seat bottoms from Acura directly.
Maybe contact them? I'm guessing if they saw enough market for something, the might make it!
Personally, I wonder if I'd get leather or just use the "leatherette" (read: vinyl). Some of those look identical and hold up way better in the long run.
My mom's Mercedes had a vinyl interior. She drove it for 5 years and never knew it wasn't real leather.
WhiteAcura2003
03-02-2016 10:55 PM
