Driver Memory
Old Apr 17, 2007 | 07:32 PM
sT04Louis's Avatar
Nikon Neck Beard Krew
Driver Memory
Alright, ive noticed this on a few occasions but now it is down right annoying. My TL wont keep my driver memory saved ie. the little green light isnt lit on 1 or 2. When i get into the car the display reads "driver one detected" and everything too. Does the car recognize the driver by which remote unlocks the car, or which remote is in the car?
Only thing i can think of, is that i keep my driver 2 remote in my car for in the mornings when i have to do PT in the army, i cant be carrying around a clump of keys.
Thanks in advance.
Old Apr 17, 2007 | 07:51 PM
datmrman's Avatar
I always thought it was the remote that unlocks the car.
If your memory lit isn't lit, are you making seat adjustments or something? After making all of your adjustments, press and hold the mem button for the corresponding remote. This should save the settings for that remote.
Best way to find out, is to experiment.
Old Apr 17, 2007 | 07:59 PM
dmarcus48's Avatar
Yes driver is recognized by the key fob, which one unlocks the car. Doesn't matter which one is IN the car, it's the one used to UNLOCK.
To save your settings just press the mem button and then the 1 or 2 button, you'll hear a double beep.
Your seat settings, radio settings, dash lighting, and mirrors are saved.
Dave
Old Apr 17, 2007 | 08:02 PM
sT04Louis's Avatar
Nah, its when i first get into the car it never lights up. I have set the memory a bunch of times, but if i move the seat at all, and want it back to where it was at, and i hit the 1 button on the door nothing happens. So i have to guess where i had the seat before and reprogram the mem.
sucks
Old Apr 17, 2007 | 08:26 PM
soli1978's Avatar
07 TL Navi AT5
I remember pressing both unlock and lock button together to activate something but I am not exactly sure where I read it...
Old Apr 17, 2007 | 08:35 PM
sT04Louis's Avatar
That just unlinks the remote from the memory system.
Old Apr 17, 2007 | 08:42 PM
cristphoto's Avatar
I've got a 2006 and in the owners manual pages 76, 96 and 103 tell various features and ways to program the memory settings. I don't recall you saying what year your TL is.
Old Apr 17, 2007 | 08:51 PM
pikespeakhiker's Avatar
4th Gear
I seem to recall something in the manual talking about automatics needing to be in park for either the save-memory or recall-memory function. I could be totally wrong. But maybe that is related to your problem. The other possibility is that someone was messing with your Keyless Entry settings and turned off some of your functionality.
Old Apr 17, 2007 | 08:58 PM
rimz's Avatar
now with four rings
i've been experiencing the same problem for a while now...and here i thought it was just me...
i've got an '04 TL...the manual says to set your settings when the key is turned to II on the ignition (and in park, of course)...i've set everything numerous times, but half the time it's like the TL just 'forgets' my settings...for example, my settings are set, i get in the car, it says driver XX detected and the green light is lit...i drive around, park it when i'm done, adjust my seat and then hit the corresponding number on the door to put my seat back in it's memorized position and nothing happens...the green light isn't lit anymore and it won't go back to the setting i programmed it for...but if i program my memory settings, adjust my seat, then hit the corresponding button again, it will put my seat back in it's memorized position...i haven't tested this with the mirrors, but it's almost as if the TL 'forgets' my settings after turning the car off or driving around for a minute...basically it remembers half the time and forgets half the time...
Old Apr 17, 2007 | 09:02 PM
sT04Louis's Avatar
Having to be in PARK may be my problem exactly. Ill give it a try tomorrow morning. Thanks guys.
Old Apr 17, 2007 | 10:01 PM
rwbentley's Avatar
Check this out. I had similar issues and had this TSB done last week. Too early to tell if it fixed the problem.
http://www.in.honda.com/Rjanisis/pubs/SB/B04-005.PDF
Old Apr 17, 2007 | 11:08 PM
rimz's Avatar
now with four rings
yeah i've already downloaded that TSB file before...but now that you mention it, that has to be my problem exactly...before the dealership had already replaced my ECU because it wasn't storing any memory settings period...but now it's forgetting them and that TSB most likely applies to it...
Old Apr 18, 2007 | 06:36 AM
TBone2004's Avatar
Team Anthracite Member
I've had my memory thing replaced two times now on my 2004 - still has this problem tho. If I see both lights not lit, I just press memory 1 and it lights up - it does not forgot where to put seat, just to put it's light on. Can't believe they cannot fix it. Oh well...not a big deal.
Old Apr 18, 2007 | 08:15 AM
sT04Louis's Avatar
Well so far today it has been working, with both remote 1&2...who knows proably just some bug in the system.
Old Apr 19, 2007 | 01:20 AM
soli1978's Avatar
07 TL Navi AT5
I was listening to the DVD Audio disc that came with the car. At the end of it, it talks about the high tech features. About the memory settings, it says pressing the lock and unlock together both links and unlinks the key... This is for a 2007 TL. It seems you already solved your problem but just FYI.
Old May 7, 2007 | 09:42 AM
6spMike's Avatar
Mike's Silver Bullet
If you have a manual, the parking brake has to be on in order for the seat to move back to the saved position when you unlock with the fob and open the door.
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
Jul 16, 2017 07:33 AM
rhdune16
Sep 28, 2015 11:31 AM
ceb
ILX
Sep 27, 2015 10:56 AM
