Drive right after start
Is it that bad to drive the car right after you ignited the car? I've seen so many ppl do that and wonder what kind of damage it does to the car?
I've never done that myself, I have a remote starter and usually wait at least 2 minutes before I drive, is that too little? too much? does weather have an impact as well?
Any input is appreciated.
It's a lot worse to do it in the winter than it is in spring/summer/fall. In the winter the oil is a lot thicker and takes more time to circulate and thin out/warm up. In the warmer seasons, it's fine to drive it right away, just be easy on the throttle until the car is up to operating temperature (or close).
Ever since I bought my, I always give mine at least 5 minutes to start up. I also have a habit of checking the Temp gauge to make sure its in the middle or where it normally should be
I'm Craig
I couldn't care less when it's warm out. I usually give the car a minute or two in winter...mostly for the sake of me not wanting to be cold as fack. Regardless, don't beat the crap out of the car until the temp gauge is ok.
Registered Member
It is not good to let your engine idle any more than necessary when doing a cold startup. A good indicator of when it is Ok to begin driving the car is the tach. When engine speed falls down to between 800 and 1000 RPM, which depending upon how cold it is may be around 30 seconds, you are good to go. Driving carefully and not fast initially for the first mile or two is about all you need for warmup.
Letting your engine idle for 5+ minutes is not a good thing.
so what kind of damage will it do if you drive right away in the winter
And SouthernBoy, why is it not good to idle for 5+? tranny killer?
So much mis-information here about cold idle and cold starting. User TLFTW above says he lets his car idle for atleast 5 minutes everytime. You do realize thats actually worse for the car than starting and driving?
The absolute best thing you can do for your car is get in it, start it and drive. The key here is drive NORMALLY. Dont get in your car start it first thing in the morning then go flooring it down the street. Wait till its at full operating temp before you do that. But as far as just starting and driving thats exactly what you want to do. Do not let the car sit and idle for periods of time. Its not doing your engine any favors and your wasting gas.
In the winter season if my car sat outside during work or whatever I like to start it and maybe give it a minute or so for the cold idle to come down just a bit, then drive away normally.
James
James
^^^ he's got a good grasp on things
normally, you shouldn't let your car idle more or less than around 1 minute depending on the make/model/engine/and oil viscosity.
on my previous car which was cast block, with 2 turbos (about double the oil and about 1.5 times the coolant) Audi suggested not to drive it for 45 seconds, but not to let it idle any longer than that.
if you don't wait long enough, you will have a "high" viscosity, and you will end up with spotty oil flow to the heads, which can be "damaging" once you get up in the rpms. but this isn't damage, it's merely accelerated wear. just wait for the idle to settle, and that's all you need to do. in summer it drops within 15 seconds, in the winter maybe 45 seconds. the ecu will let you know when it's time to go.
on the other hand, waiting too long, you will have spot heating, which is very bad. trust me when i say this, you can idle a car to death. i've done it (by accident, and it took 3-5 hours) before and had to completely junk a cast block because of the temper change from the heat. obviously this example is extreme.
now, to answer your question, if you have a manual car that's the easiest way to learn when your car has *actually* reached operating temps and until that point where all sluggish-ness disappears you should be driving as if you were in a funeral procession. if you always baby your vehicle for about the first 5 miles you'll never see a problem due to any of this stuff.
also, remember to take it easy the last mile or 2 before your destination so that you can avoid more spot heating once coolant and oil have stopped circulating.
James
James
Starting from tomorrow that habit is gone. I just got my TL and only recently started doing it because I thought a extra long warm up was good
Also sort of related in a way, but the other thing that irks me is when I see posts or see people starting up cars that have been stored. Since I am on the corvette forums lots of those cars get stored winters and you read of guys that start the cars and literally let them idle for 30 minutes. Infact I saw my neighbor doing that with his 08 C6 vette I heard the exhaust just idling for 30 plus minutes and I just cringed. Anytime I store a car or it sits for an extended time I do not start the car whatsoever unless I plan on driving it and allowing the car to reach full operating temp.
Im glad you got the info you were looking for so the cool thing for you is the best way will save you time, gas, and slight wear on your engine. Its a win win. Get in it and go, but drive normally until everything is warmed up completely then lay into it if you so desire :-)
Registered Member
Extended idling from a cold startup promotes condensation in the engine and crankcase. This is a normal byproduct of combustion in a cold engine but you want to get past this quickly. This extended idling, again from a cold startup, also increases acids in the crankcase. And then there is the exhaust. If you spend too much time idling a cold engine, there will be quite a bit of condensation buildup in the exhaust. If you couple this with a short trip to work or slow traffic, you will not burn off this moisture completely and the result in the onset of rust.
Best to start the engine give it a moment for it to wind down to around 1000 RPM or so, then start moving. Driving though a neighborhood before hitting a highway is a very good idea. And if your commute is short and close, consider taking a round about way to give your engine a little more time to warm up completely and for it to help burn off moisture and other contaminants.
The worse thing you can do on a cold morning is to start the engine, run the defroster on high (to remove frost on the windshield), then go back inside for a cup of coffee or two. You engine and other parts will not like you for this.
Dogmatic Dinosaur
The transmission and engine are fully lubricated in about one second. Feel free to drive easily after that. If you need to get on the pedal instantly, then little bit of time until the HU comes down is probably a good idea.
The high idle is not for reciprocating assembly lubrication.
How do you drive if you windshield is all frosted ...I'd rather idle until it's defrosted than drive into a tree
Keep Right Except to Pass
http://www.brookstone.com/review/pwr...NOW-SHADE.html
Regarding the original question, I saw a recommendation somewhere once that you not rev above about 4000 rpm until your engine warms up as seen by the temperature gauge and by the tach needle dropping to a regular idle speed when you're stopped. I recall one time before I saw this recommendation I had gunned it getting on the highway during the winter before the engine warmed up and I noticed a coolant leak from one of the hoses when I parked the car (so I got back in and took it to the nearest service station for repair). I don't know whether gunning the engine in the cold could have caused that, but I've always been careful since then and the problem hasn't repeated....
Received 6,470 Likes
I usually try to wait and drive after the nav system comes up. In the winter, I just watch the temp gauge until it starts moving to it's normal temp before I open it up.
LESS THAN ONE MONTH AWAY!
2011 National AcuraZine Meet-Kansas City-June 12, 2011
Sign Up and Details Here!
Either scrape it or avoid the problem altogether by putting a cover over the windshield during the night. There are a variety of these things on the market; in the morning, you simply remove it, throw it in the trunk, and go on your way (having the trunk tray is advisable due to the possibility of ice melt). This particular device has probably been discontinued (my parents gave me one back in the late 1990s and I still have it....works pretty well in the rare event I park outside during the winter), but it will give an idea of the type of product I mean:
That item is a good idea if you live in a good neighborhood! It'd get stolen in a second where I live
Registered Member
You can put a large plastic trash bag over the window and you'll find that helps a heck of a lot.
But there is this. It's your car and you have every right to do as you see fit, regardless of whether or not it benefits your machine. Your money, your property, and your decision to take.
Just buy an ice scraper at any auto parts store.
BANNED
More a concern for the engine, but yes, the transmission and other moving parts need to get moving to get up to operating temperature as soon as is normally possible.
when i was in WY going to tech school i was driving a '98 v6 accord with 225k miles. i had to warm that car up for 5-10 minutes every morning or the transmission would clunk and slip on my 5 mile commute to school. i'd hand off a trans failure for accelerated wear and more frequent oil changes
http://cgi.ebay.com/NEW-Snow-Windshi...item53e7a75a8a
