Door panel removal
Door panel removal
I tried to remove the driver's side door panel on my TLS today so I could install moleskin but was unable to do so because the screw with the bumper on it would not come out. It just spun. Anyone have any suggestions?
~Da Nocturnal Cheetah~
I think this should work, it's what I used to do to screws like that before.
x2
I have experienced these stubborn screws on two different TLs. You will need to stop it from spinning in the back somehow. A needle nose plier will help.
06 TL 6spd. Navi/A-spec
I had the same problem i just shoved a flat head screw driver in between the panel and the door right near the screw and pried up a little, while doing this unscrew the screw and it should catch. It worked for me, hope this helps you.
Yup! That's exactly what I would do!
BoricuaTL
04-08-2016 01:08 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
