Door Panel clips--Help!
Old May 4, 2016 | 10:27 AM
QuickTL07's Avatar
I need your help guys,
My door clips ware out from mounting and dismounting door panel, and I need to buy new clips.
I have order some from ebay 2 different kind that stated for Acura TL, but that wasn’t the case….
I have also tried to look for the right part number and didn’t get any help, called the dealer and I got nothing form these duschbags.
Can someone point me at the right direction, or the right product number or even a link where I could buy them. I really need them asap.
Thank you much for the help
Old May 4, 2016 | 11:38 AM
Adobeman's Avatar
The DVD-A Script Guy
Go here https://www.acuraoemparts.com/
and put in your year and model info and then I'd say look for the door lining diagram for either front or rear. ( you didn't say which). There are a ton of snaps and clips on the diagram so it's up to you to know which you need.
Also, tell us your year and provide some pictures of the clips AND clearly where they are on the door panel and someone may be able to help.
Old May 4, 2016 | 03:04 PM
QuickTL07's Avatar
Thank you for the info, but its so hard to find the damn clip ...
Old May 5, 2016 | 11:45 AM
QuickTL07's Avatar
Sorry I wasn't clear enough,
I have 07 Acura TL with nav...
I have ordered some from ebay, but they were not good, to small and didn't even catch the doors at all...
Old May 5, 2016 | 12:08 PM
sockr1's Avatar
hey mario post a pic of what you're looking for (at least of your broken ones) and maybe we can help out. i'm not sure what you're wanting
Old May 5, 2016 | 02:09 PM
QuickTL07's Avatar
White clips when you take the doors off, you will white clips, there's about 10 of them around the door panel. ill show you a pic....
Old May 5, 2016 | 02:12 PM
9 91560-S84-A01 CLIP, DOOR LINING (NATURAL)
$2.07 $1.53
OEM Acura TL 2007 FRONT DOOR LINING parts
it really wasn't that hard at all..
i literally just followed his exact directions..
Old May 5, 2016 | 03:12 PM
QuickTL07's Avatar
Thank You...
Hope they will hold my door panel... Name:  IMG_20160504_182611_zpsb0qk17fg.jpg
Old May 5, 2016 | 04:36 PM
sockr1's Avatar
your issue may not be the clip but actually the clip not fully engaging in the door frame. when i did my doors with ensolite and dynamat i had to be very strategic how far to the outside i put it, because if you go too far outside and it's too thick, then the clip will never fully insert into the spot on the door (hope that makes sense)
long story short, make sure where the door panel and door frame meet up is not so thick that you can't push in a clip
Old May 6, 2016 | 09:43 AM
QuickTL07's Avatar
Thank you for the input, the doors go on perfectly fine, I have replaced my clips and didn't know where the heck i put the old ones at...
I bought some generic ones from ebay but there were not the correct size...
I'm sure once i get the replacement for the bottom portion they will clip in without any issue....
Thank you for the help...
Currently running all Hybrid Audio L-SE version
And will be replaced with Sinfoni after May14... after ISQ competition.
