Door Locks
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
This is a bit random, but I bet it has been discussed or at least thought about before. When I was at AutoZone recently I noticed they have some aftermarket metal door locks (bar shaped) for sale. Has anyone replaced the OEM door locks that move up and down on top of our doors? Do they simply unscrew and pull off?
I like to rest my arm on the window seal when the windows are open and I'm cruising, however even in the locked position that knob digs into my arm. I was wondering if there is an aftermarket fit that might be shorter and flush with the door when in the locked position.
Yes, this is a minor complaint, but its annoying...any experience out there? By the way, I have a 2006 RBP TL.
New shoes on my
The aided inside the car had a seizure (which was the cause of the accident) and we needed to get them out for EMS to treat and transport. We tried the door handle, but the doors were locked. We then broke the window and went to manually cycle the lock, no luck, the person had taken off their lock stems as I mentioned above. We tried the power lock button, no juice.
So now, we had to take the Hurst tool (Jaws of Life) and do a door pop, completely wrecking this person's drive side door, part of the passenger door, etc.
The frontal damage was repairable, the car wans't a totoal loss, and now there was a ton of side damage from us. All could have been averted by just leaving the damn things alone!
Also think about a self rescue situation where you lose power but need to get out of the car and it's locked. Do you carry a window punch or a rescue hammer? Doubt it.
Full of water...
That looks nice, but I'm a FF here in NY and we had a call sometime ago where someone who took them off completely (same effect as when they're cut short and down, essentially you can't grab them with your fingers) and we had a car accident where there was frontal damage, but the rest of the car was fine, however at some point in the accident, the negative battery cable came off.
way to ruin my morning...downer!!
New shoes on my
Haha, sorry man! I'm just looking out for the well being of my Acura brothers!
I know some of us would feel worse after seeing the extra damage to our babies than as a result of the damage our bodies took! HAHA
Really?
Smoke, have you done this? What did you use to cut them down?
Welcome to Azine NPO1026..."Search" + patience is the key (i understand there are many info in the garage, but you just have to be patient and look around case it's very helpful)
Anyways, here is the link to help a noob out:
https://acurazine.com/forums/3g-tl-2004-2008-93/f-176-new-mod-door-lock-button-586146/
You could adjust the height of the knob anyways so it doesn't go all the way down...just make sure you adjust it so you could get a hold of the knob somehow (just incase something freakish happens).
Compared to the picture in the link, i did my knob a little higher...but enough not to bother my elbow while driving. Another thing i did is the rear lock are a tad bit higher than what i have in the fronts, because no one hardly rides in the back.
Good luck with the mod...it's super easy!
MrHeeltoe
20
02-23-2023 01:54 PM
soupi
14
11-15-2015 11:15 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
