Do your RPMs rise a bit when shifting?
'08 TL-S 6MT
I think I've noticed sometimes that when disengaging the clutch, my rpms rise about 200. Google searches show that is common because the load of the clutch is off, but I'm wondering if it could also mean that my clutch is slipping? :S
Noticed this at 3rd-4th at 3K, it would rise slowly to 3.1-3.2 when disengaging the clutch. I think my clutch is good as I can get going off a stop from 1.1-1.2K.
justnspace (03-20-2012)
'08 TL-S 6MT
Nope, foot is off throttle completely. I've read that it could be a sticky pedal. Wasn't sure. It does happen only sometimes. Does the RPM stick or rise though?
mcmguti (03-20-2012)
the overexplainer
it's the fly by wire throttle. there's a certain lag when releasing the gas pedal. If you dont want it to happen release the gas a split second before you disengage the clutch.
Dont worry about clutch disk wear, as long as you disengage the clutch quickly and smoothly little to no wear is occurring. Engaging the clutch is where the wear happens.
'08 TL-S 6MT
Thanks y'all. I'm still trying to get this baby to be smooth 1-2-3. Do you guys shift the second you get off the throttle? I would think so because of the feature you mentioned as the RPMs don't hold for longer than 2 seconds? I *think* my shifts are smoother when I disengage the clutch about .5 sec after letting off the throttle.
Because I bought this car used and it's the only 6MT TL that I drove, I don't have much to compare to in regards to clutch slippage. I can engage the clutch from a stop within 1.2k so wouldn't this mean my clutch is still good?
Can a poor clutch be related to jerky shifts?
^fact is, this is one of the HARDEST cars to learn/drive properly.
my dad gave me a 2010 challenger srt for a month, and I learned that clutch in one day.
the TL took me over 3 weeks to get right, even now i have trouble with jerky shifts.
why didnt the TL use a conventional clutch system.......
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
the overexplainer
in older cars jerky shifts can be caused by the dampening springs in the clutch disk popping out or getting damaged, not so in the TL (no dampening springs). It's probably just a matter of getting used to it.
Some would suggest deleting the master cylinder valve which slows clutch engagement (takes the place of dampening springs in the clutch).
IMO, unless you track your car this is not necessary. I can shift fairly smoothly day to day without the delete.
A tip, the 1-2 shift is extremely slow (take your time moving into 2nd and releasing the pedal, relatively speaking), and the shifts get progressively "quicker" from 2-6. the rpm differential from 5th is not far from 4th, and I find myself sometimes shifting too slow (i take too much time between getting into 5th and engaging it), just missing the sweet spot engagement point.
There's nothing I hate more than cars that are programmed to hang the throttle between gears. Let the bad drivers learn to drive a manual, don't punish the ones that do know how to drive.
'08 TL-S 6MT
why didnt the TL use a conventional clutch system.......![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
picking up and mastering the SRT8 clutch in one day was awesome. No jerky shifts, passengers thought it was an automatic, etc.
with the TL, I have to use a lot of concentration just to get going. not to mention its FWD and I have to be careful of wheel spin and torque steer.
after 2nd gear, its all gravy!! very easy after that!
To answer ops question the car only blips the throttle for you when you are applying adequate amounts of throttle. It does this to burn off excess fuel and vapors that are in the engine already. If you baby the gas pedal, it won't do that. Thats my best answer anyways.
PS worst car to shift in.
jeeva86 (03-24-2012)
How about skipping 2nd when you don't need it? I shift directly into 3rd much of the time, assuming that I don't need to accelerate quickly. It's probably not a fuel efficient but I take 1st up to about 2500RPM then shift into 3rd. At the same speed, 3rd is probably about 1200-1500RPM? Dunno for sure. But it's certainly well above "lugging" it, again, assuming you're cruising and not trying to get from 0-60 in 7 seconds. When I'm taking off I always use 2nd. But it's when you're accelerating slowly that going from 1st to 2nd is difficult, not so much when you're gunning it.
Registered Member
Registered Member
The clutch pedal travel is relatively short with an even shorter takeup. Takeup is the distance the pedal travels from initial engagement to full engagement. IN our manual TL's, this is pretty short. Initial engagement is spec'd to take place approximately 2" from the stop pad. This is rather early in the pedal's travel. Now couple this with a very short amount of travel from the point of initial engagement to the point where sufficient pressure is being applied to the friction disk to move the car and there is not much room for error. And finally, first gear is VERY short with a ratio of 3.93:1 and there is a wide ration spread from first to second (2.48:1) which tends to cause people to jerk and buck the car until they're use to things.
Hope this helps.
Registered Member
Registered Member
"When I'm taking off I always use 2nd."
You should never do this. You have a first gear for this... use it. Never start of in second gear.
Registered Member
What most people do during skipped upshifts is to shift just like they do during a normal shift. What they don't realize is that this forces the synchronizers to work much harder to match shaft speeds.
CheeseyPoofs McNut
10-11-2015 11:25 AM
HeloDown
09-08-2015 06:51 PM
