DIY Type S sidemarkers?
i just got my tl-s sidemarkers for the rear and i didnt see a DIY in the 3g garage. can somebody help me find it or can somebody tell me how to get to the sidemarkers?
KICKED IN THE BALLS
First open your trunk. There are two knobs you need to take off of each side. One is located right beside the hinge arm of each trunk arm then you need to remove one knob from each of the side wheel well. pull the fabric away from the body and you will see a plastic white piece and has something connected to it, that is your side markers. Unhook the connector from the side marker then there are tabs on each of the side marker just push them in and push the side marker out. Hopefully that made sense. If not I will pull a diagram and get the numbers out for you.
SUPRMN84
10-07-2015 09:46 PM
justin.w13.walker
09-22-2015 02:21 PM
