DIY: Supercomputer pedal install 3G Garage #F113
#42
Originally Posted by sistim turbo
after securing the race pedal to the rubber brake pad,,,,,,has it held up? do u notice any slipping etc. ?
looking forward to your response..
thanks so much
thanks so much
#44
Racquetballer
Just did this install and would like to thank Buda, Pikabb and everyone else who had input. I mounted my brake pedal on the rubber cover per pikabb's instructions and it worked out great. I have to admit, the gas pedal was by far the worst as I had to really get in there to screw on the bolts and maybe it's me, but my dexterity in close quarters is somewhat meager at best. All in all, it's a fairly easy install and really adds to the interior look of the car. Special thanks to morphguy12 for selling me the pedals and being an awesome seller.
#46
2007 NBP TL Type S
I installed my about two or three weeks ago in my type s. man it was hard removing the brake and gas pedal because its held in by rivets. but after the install it looks great
#48
2007 NBP TL Type S
Check the Black market like I did. I waited awhile until someone posted them for sale, and I jump on it real quick. I check the black market like everyday. now all I need is the Illuminated Door Sills in red.
#49
Thanks just used these instructions! I dont know how you get the washers on the two top gas pedal bolts.. its IMPOSSIBLE!! haha.. I didnt put them on and they are fine. Thanks again! These are the ebay ones, not the supercomputer ones.. I got these because it has the matching gas pedal.
#50
Thanks for this DIY. I just used it to install my pedals from:
http://www.uniquestyleracing.com
I used the "Attach to the OEM Brake Rubber" method and they turned out well.
#53
Ah - so glad I saw the note on the brake pedals. I stopped after the gas because it was getting dark and I was having a hard time figuring out a good way to drill through the metal.
Another tip for the install (the gas pedal) is to use a 6mm extension. That way you can drop the nut into the hole and put the washer on top of it then slide it in when you have the pedal leveled (assuming you're not taking it off at the top). This may it much easier to put the 2 top nuts and washers in.
The car look so much more aggressive with the pedals! Super awesome!
#54
![](http://im1.shutterfly.com/media/47a0db26b3127ccefa5bbafbf8af00000060O28AcNmzZm1ZNAe3nww/cC/f%3D0/ps%3D50/r%3D2/rx%3D550/ry%3D400/)
#56
Just finished installing my pedals. Thanks to bforbrian for the deal, Buda for the DIY and Usalinh for the tip on the brake pedal. I did it the same way (attaching the Supercompter pedal to the old rubber avoiding the need to drill through the brake pedal) and it seems to have worked great. It feels sturdy and saved me a lot of work. Here are some pics to add to the DIY...
Supercomputer brake pedal after being attached to old rubber....
![](https://img401.imageshack.us/img401/9214/31149694oh9.jpg)
Underside where you can see the bolts that need to be cut down. I used a Dremel with a cutting disc and it went through the butter...
![](https://img151.imageshack.us/img151/2001/10433948ja0.jpg)
Here's a side shot of the brake pedal after installing...
![](https://img151.imageshack.us/img151/3940/68223850im0.jpg)
The finished product (spring cleaning is coming)...
![](https://img401.imageshack.us/img401/6779/71032962xk8.jpg)
From a distance...
![](https://img151.imageshack.us/img151/6514/50055200sy0.jpg)
With my dirty all weather mats (I like the look of the silver on black)
![](https://img151.imageshack.us/img151/9775/66037562lo0.jpg)
From a distance...
1. Remove brake rubber
2. Line is up on the alum pedals
3. drill holes into the rubber (when it's lined up with alum pedal)
4. put rubber back on floor pedals
5. user holes as guides to drill into medal (much easier than holding the damn alum pedal)
Worked perfectly for me :-)
#57
Unique Style Racing Pedals
Hey, thanks for the excellent write-up! I used your instructions to install the Aluminum set of uniqe style racing pedals. That brake pedal was a mutha! Ended up breaking 3 drill bits... and yes they were the titanium, but I will admit that I was pressing hard and down at an angle which is what contributed to the breakage...
Sorry for crappy pic, but only had my old school non-smart phone to take when I was done:
![](http://img861.imageshack.us/img861/8048/0117021544.jpg)
Uploaded with ImageShack.us
#59
From a distance...
From a distance...
#60
I recently installed a set that I bought on eBay. Check out my thread:
https://acurazine.com/forums/third-g.../#post16071192
mugen_kid
11-13-2015 10:38 PM
Skirmich
09-15-2015 06:41 PM
kixo
09-05-2015 08:54 PM
acura, acurazine, aluminum, brake, dead, diy, installing, peadal, pedal, pedals, racing, supercomputer, supercomputers, tsx, version
