DIY: Replacing Cabin Air Filter 3G Garage DIY F-130
Old 01-12-2011, 07:50 PM
  #281
CLeanSteve's Avatar
Good thread. Bought mine with 50,000. Sure this needs to be done.
Old 03-05-2011, 12:42 PM
  #282
6th Gear
dj_vesper's Avatar
This was super easy. Changed ail filters on both of my TL's in about 30 mins total. Thanks!
Old 03-07-2011, 06:30 PM
  #283
4th Gear
reef888man's Avatar
is the glove box suppose to drop down when open? i'm not sure if i put it together right.
Old 03-07-2011, 06:45 PM
  #284
Make it so
DuoDSG's Avatar
Thumbs up
Not all the way, it should open up only as far as it was before you started.
You're missing the two gear clips that go on either side of the interior of the globe box (they are black, they look like tetris pieces with little black wheels with teeth on them). They clip in and prevent the glove box from falling all the way down.
Old 03-07-2011, 06:50 PM
  #285
Make it so
DuoDSG's Avatar
Thumbs up
Found some pictures (on the first post of this thread).
The clips I am talking about are the ones in the following two pictures (on either side of the glove box interior):
Also, make sure you've clipped in the telescoping hinge that is in the bottom right portion of the picture:
Old 03-09-2011, 01:47 AM
  #286
4th Gear
reef888man's Avatar
are there clips on the 2006 tl. i dont think there were clips on either sides.
Old 04-02-2011, 03:54 PM
  #287
the overexplainer
ez12a's Avatar
just got done doing this on my 04.
No clips inside the glovebox, instead you had to slightly bend the sides of the glovebox to get it to swing down.
Broke one clip pulling the glovebox housing out..closest to the valet trunk switch. Put it all back in and it seems to hold. It's going to bug me so I'll probably superglue/epoxy it when I have time/materials.
the old filter was way dirty...i wonder how all that crud gets in there..
Old 04-02-2011, 04:37 PM
  #288
SSM4DR's Avatar
http://www.youtube.com/watch?v=FQsDxqxyeqM
I just changed mines today also .
The following 3 users liked this post by SSM4DR:
AcRightLINY (06-22-2011), Airblizzard (06-10-2012), DooooT (07-05-2011)
Old 04-06-2011, 11:57 AM
  #289
aquariussuperman's Avatar
Post
Price Update for RockAuto.com:
Cabin Air Filter
ATP HA5 = $13.13 ('activated carbon' filter)
WIX 24815 = $10.64 (regular filter)
Engine Air Filter
Wix 49224 = $12.40
I ended up buying the 3 of them together, so I have an extra cabin filter for the future. Total with shipping was $43.09, so it's cheaper than amazon.com at this time.
Old 04-07-2011, 01:42 PM
  #290
rico651's Avatar
damn, didnt know i was supposed to push the center of the clip in, just broke mines off =(
hopefully its not too detrimental. i'll post pics up soon!
Old 04-07-2011, 02:05 PM
  #291
av2600's Avatar
[quote=aquariussuperman;12845601]Price Update for RockAuto.com:
Cabin Air Filter
[/quote]
you need to replace both of these, or pick one or the other?
Old 04-07-2011, 02:08 PM
  #292
the overexplainer
ez12a's Avatar
pick one. Carbon being a superior choice.
Old 04-07-2011, 02:19 PM
  #293
av2600's Avatar
sweet, i'll be ordering today. thanks again for the quick help!
Old 04-08-2011, 01:58 PM
  #294
borrowman's Avatar
There is also a $5 rebate on the ATP HA5 right now.
Old 04-08-2011, 10:43 PM
  #295
av2600's Avatar
looks easy enough, im going to try this in the morning
Old 05-22-2011, 08:17 AM
  #296
ibeplato's Avatar
hi all, i changed mine again in my '04 TL yesterday and broke one of the two push-pin clips (the little round plastic clips that have a pin in the center - bottom picture in post #285 above). Believe or not, I somehow managed to lose one of the two screws that holds the glove compartment on (not a good day).
Does anyone know the part numbers for both, and if I can order on -line?
Old 06-12-2011, 07:53 PM
  #297
7th Gear
smithlua's Avatar
Wow, mine was long overdue.
Old 06-13-2011, 12:26 AM
  #298
denny crane's Avatar
I replaced my filter about two weeks ago. It was pretty simple other than breaking one of the push clip. One thing I almost missed when placing the filter back in the tray and I haven't seen this mentioned on this forum:
You must place the edges of the filter in the slot of the tray or you will have an opening in the filter element.
If someone posted this I missed it. If you have yet to replace your filter don't miss this important step.
Old 06-13-2011, 10:12 AM
  #299
sodaks2k's Avatar
I checked my cabin filter a few days ago. It took less than ten minutes to do. I'll probably end up cutting an access hole since where the screws go in seam like they will strip easily.
Old 06-22-2011, 05:53 AM
  #300
bigran23's Avatar
Thanks for all the instructions and tips on changing the cabin filter on my 02 TL. With all the info changing the filter was a cool breeze.
Thanks guys.
Old 06-22-2011, 08:52 AM
  #301
space_bound's Avatar
Yeah it was very easy. I had to do it twice though because I didn't pay close enough attention and just put the filter in instead of looking at the air flow direction.
Old 06-22-2011, 11:37 AM
  #302
Balling in the...
Mafyoso's Avatar
I did the SAME SHIT. I broke mines I didn't know you were supposed to push them in. I may stop by the Acura Dealer or Online to Order a few Clips I need for the car anyways. Sucks ass tho because it could have been avoided
Old 06-22-2011, 09:13 PM
  #303
MyBabysBaby's Avatar
I did a search on cabin air filter today and came across this:
https://acurazine.com/forums/1g-rdx-diy-faq-161/diy-cabin-air-filter-replacement-681583/
Why couldn't it be that simple?
Old 06-22-2011, 10:45 PM
  #304
H22CB7's Avatar
I'm doing mine tomorrow after work. I have 80,000 miles and believe it's still the original filter in there. I want to open it up and see how filthy it is. By the way I'm not a Fram filter fan but I was at Walmart today and seen the Fram fresh breeze filters on clearance for $4.00. I figured why not, it's just a cabin filter.
Old 06-23-2011, 05:40 PM
  #305
H22CB7's Avatar
Changed it a few hours ago. Pretty easy and only took about 10 minutes taking my time.
Old 07-27-2011, 07:43 PM
  #306
Team SSM Queen
narnia's Avatar
I just changed my filter again. My car is 7 years old, so I've probably saved well over $500 doing this myself instead of having the stealership do it all these years. This forum is awesome!
Old 07-29-2011, 10:21 AM
  #307
joelmatt89's Avatar
i am about to order one of these for when i get back home. For the past three months my work has been on a really dusty jobsite. I tried keeping my car clean for a while then gave up in one week it literally gets as dirty as normally would from 2 months. I hate driving in a dirty car but i can't wash it once a week and i won't go through an automatic car wash.
Anyways i can tell the fan is working super hard and the air is not fresh anymore at all it has a distinct dirty smell.... def need to do this.
Old 08-01-2011, 10:55 PM
  #308
Facemask's Avatar
Just checked mine today, seems fine for now. Just started working on all my cars at home the last few months. Been getting ripped off SEVERELY from what I can tell for years now. Charging upwards of $150 for a dang Cabin Filter! BS. Not having money to spend on repairs really opened my eyes up to the thievery the dealers (and some auto shops) take from customers.
Anyways, also broke one of my clips and may have to recheck the replacement of the housing because there is a little gap towards the corner.
Thanks for all your help fellas!
Old 08-03-2011, 03:38 PM
  #309
GeaugaDog's Avatar
Just got done changing my filter out, was easier than I thought it was going to be! Glad I could save close to $100 by doing it myself instead of doing it at the dealership lol
Old 08-08-2011, 09:18 PM
  #310
8th Gear
Sleepy_Steve's Avatar
Glad I found this thread. Cabin filter has been on my to-do list for some time now.
Its an '05 and has 130k on it... Smells a bit off inside if I switch it off of circulate.
Old 08-11-2011, 07:07 PM
  #311
Shahk's Avatar
This was easy to switch out, my car had 57k miles and it wasn't too bad but definitely needed it.
Old 08-11-2011, 10:52 PM
  #312
Imabeast31's Avatar
took me all of maybe five mins... and you can immediately smell the difference in air quality
Old 08-12-2011, 01:11 AM
  #313
3rd Gear
LovingMy06TL's Avatar
Just replaced mine yesterday. I didn't have the clips, but figured it out pretty easy just by pushing the two sides inward. The wife has been wanting me to do this, and says she feels a difference in the air, we also just got more coolant, so who knows. This definitely beats doing it at the stealership for 60 bucks. great DIY guide.
Old 08-27-2011, 12:38 AM
  #314
GeaugaDog's Avatar
Great DIY thanks! Bought my car around 50K miles so I figured this needed to be changed. Wasn't that hard and didn't take too long at all.
new vs old
Old 08-27-2011, 01:44 AM
  #315
Early Shifter
ohsixMTee's Avatar
Great thread, I apologize if I missed the information but how often is this supposed to be done?
Old 08-28-2011, 10:38 AM
  #316
sodaks2k's Avatar
It's in your owners manual.
Old 08-28-2011, 10:59 AM
  #317
sodaks2k's Avatar
And in case you don't have one, it says every 15k if you drive primarily in urban areas.
Old 08-28-2011, 11:04 AM
  #318
Shoeface's Avatar
Great guide! I'll be doing this next month
Old 08-30-2011, 02:21 PM
  #319
mb1976's Avatar
Great video on this but ended up breaking off one of the plastic clips when I was removing the last part according to the video. I could care less about that piece now being it is easier coming off now as well as going back on. Replaced it with the Fram Fresh Breeze filter
Old 08-30-2011, 03:02 PM
  #320
sodaks2k's Avatar
I went to rockauto.com and they have a $5 mail in rebate for the ATP charcoal filter. Part # HA5
https://www.rockauto.com/lang/en/promo.html
Quick Reply: DIY: Replacing Cabin Air Filter 3G Garage DIY F-130
