DIY Oil Change Checklist with service manual scan 3G Garage #C004
#82
Originally Posted by jcampi
I'm expecting to change the oil in my '05 Acura TL soon and would like to be prepared. Does anyone know the oil bolt size? I'm assume it's a metric bolt. Thanks.
#86
Sorry to be a pain Ron, but the one in there is THIS thread....I was looking for a DIY guide with pictures on changing oil...(not just the service manual scans)
I could've swore I saw it somewhere before, but cant seem to find it...
#87
Originally Posted by nyTLer
Does anyone have a link to the DIY Oil Change thread...a search doesnt seem to work, im thinking b/c 'DIY' and 'Oil' are too short of words to search on...
https://acurazine.com/forums/showthread.php?t=139528
Here's a hint when searching for 3 letter words. Put a * after the word, like oil* and it will find it for you.
#88
I recently changed the oil in my '04 TL and now I have a leak around the oil plug. I did read in the manual that the seal does need to be changed because it is a one time use seal. Like many on this forum, I never had to change the seal on my Toyota, so did not figure I had to do it on my TL. Well, I was wrong. Now the question is, do I wait until I need to change the oil again and keep wiping up the oil spots, or do I get a new seal and change the oil again. Any thoughts? I will keep checking the oil level in the mean time.
#90
I have changed my own oil in my 04TL for over 3 years now, and change the gasket every 3d time and have never had a problem, and many others do the same thing.
It's true it is cheap, but if it hasn't been abused by overtightening some of us feel it isn't absolutely necessary to change it each time, so let's lighten up on the noob and welcome him to the forum instead of attacking him in his first post.
It depends on how much is leaking, how you drive, and how comfortable you would feel on a long trip, whether you should change the gasket now or wait until the next oil change.
#91
Originally Posted by pekkieboyz
Frist of the seal is cheap. Why didn't you change it in the first place>? were you that cheap. this serves you right
As I and as others have said, I have not had to replace the seal in the past and thought this was same situation.
#92
Originally Posted by Ron A
Did you just get this 04TL and is this the first time you changed the oil in it? It's possible the previous owner never changed the gasket and that is your problem, or it could have had the wrong gasket. Or is this just the first time you neglected to change the gasket?
I did just get this car and this is the first time I changed the oil. I think from now on, just as a matter of practice, I will replace the seal. It gets old cleaning up the oil from the garage floor. Not alot, but enough.
#93
I'm your Huckleberry
Originally Posted by 2obsessed
Just changed my oil, and I want to second Pug's comment on getting a big oil pan to catch the oil. It SHOOTS out about a foot when you first take out the drain plug. I got oil everywhere - had no idea it would shoot out so far - guess it is the thin oil. You ideally should have a pan big enough to catch the shootig oil stream, AND the drips that drip straight down from the drain hole while the oil is shooting out. This will require a pan about 18 inches long. My thing didn't come close. What a mess.
Also, I picked up the oil filters at Acura, and they came with a new drain plug washer taped to the top, which was cool. Original washer looked fine, though.
Just my
#94
I hate oil leaks of any kind and I have plenty of them in my classic British sports cars. While a few drops on the garage floor are a nuisance, your engine is not under pressure while parked. When driving, there is a certain amount of pressure in the pan (but not the same pressure in the oil system) that causes it to leak at a bit higher rate. Where does that oil go? Not just on the pavement, but all over the underside of the car. Not pretty, a dirt magnet and a pain to clean up. I use a new washer every time!
#96
Received 2,600 Likes
Originally Posted by ReD-BaRoN
Where do you get this? Dealer only?
#97
Originally Posted by Pug
Oil life is now <10% (4 months, 4800 miles), so I'm fixin' to change the oil this weekend. I want to do it myself because the dealer is a rip, and I don't trust the quickie-lube places.
Looking for input on what I need to buy to get set up. No detail is too small, because I'm starting this from scratch. So far, I can think of:
- 5 quarts Mobil 1 0W-30W;
- Oil Filter (I'll search other posts to find out which one);
- Gasket for the oil plug (from Acura);
- Ramps (I'm doing this in my driveway, and recs on which ones to get?)
- Filter wrench (suggestions on which wrench to get?)
- Something to put the used oil into.
I have access to Target, R&S Strauss and PepBoys. No Wal-Mart nearby.
Thanks for any and all help !
Misc. Information: Use 17mm socket for oil bolt. Crush Washer for oil bolt (part # ACC9410914000). FRAM Extra Guard PH7317 oil filter (Use small size filter wrench with handle for oil filter). Washers are ~35¢ each.
Procedure for resetting oil reset indicator in 2005 Acura TL
1. Go to oil life in multifunction/trip computer.
2. Hold down Select/Reset for 10 seconds (until the Service Indicator comes up in Orange), then let go.
3. Hold down Select/Reset for ANOTHER 10 seconds (until it brings up the Reset <OK> notification), and let go again.
4. Then Press the Select/Reset a final time (just normally) and it will reset oil life to 100%.
NOTE that if you press one of the arrow buttons after the first time, it will turn on the "Service Notification A" (and associated "message waiting" indicator)
I have no issue using Fram oil filters. I get them from Walmart for about $3.50 each. I also purchase my air filters at Walmart along with the oil. I don't believe in the propaganda about oil brands. As long as the oil if certified and a name brand. I have even used Walmart's brand of oil. I like getting the oil in a single large container. Good luck on changing the oil.
#100
AZ Community Team
Received 7,771 Likes
Originally Posted by joerockt
Does anyone know if the filter is the same on the 3.5 as it is on the 3.2?
Search "PCX-004" or "PLM-A02" for much Oil Filter discussion.
#101
Just dial 1911
1 Post
Originally Posted by Bearcat94
Yep, they are the same. Current Acura part number is 15400-PLM-A02, made by Fram ( ). There are better filters - Mobil1, Honda S2000 (15400-PCX-004), etc.
#104
Good advice, Ron A. I have ramps and extenders for my ramps. I paid about $20 for each at Kmart. The extensions were designed specifically for my ramps and act like the wood you talked about. It's plastic and attaches to the bottom of the ramp and in essense lowers the approach angle so nothing scrapes. They are essential esp. if you have the front lip underspoiler. Don't forget to apply the handbrake and chock the rear wheels for added safety. Your other choice would be to use jack stands. Ramps are quicker, though.
Sounds great, never saw those before, will work great on our low cars.
#106
AZ Community Team
mada51589
05-03-2022 08:54 PM
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
