DIY: Full LED interior conversion step by step
Hi Everyone,
I decided to start new thread for full LED interior conversion for Acura TL 04 to 08. I read all thread for LED conversion they are very helpful to me but no one is complete and step by step. Since I decided to upgrade my interior with LED I was really confused about number of LEDs I need, what type of LED. After reading all thread and DIY here is my conclusion.
First Step: total number of LEDs by location and type of LEDs
Data sheet for Interior LED conversion
Preferred LED Types:
Volt: 3.2v/ 3.5v (with resister)
12v or 14v for direct use
Current: 20 mA to 40 mA
CMD: min 8000 max 12000 (8500)
Type: 3mm round flat head LED, and PLCC-2 SMD
Color: Daytime White (6500K)
Blue
Position Type of LED Color Volt Description Qty.
1. HLF Unit PLCC-2 SMD or 3mm Blue 12v/3.5 Garage Memory switch 03
3mm with Adaptor White 12v/3.5 Moon roof Switch 01
3mm without adaptor White 12v/3.5 interior light on/off switch 01
2. Climate Control 3mm with adaptor White 12v/3.5 both side, 4 each side 08
Non NAV, (with NAV add 4 for bottom)
3. Hazard/ Airbag 3mm with adaptor White 12v/3.5 Hazard light 01
3mm with adaptor Blue 12v/3.5 passenger airbag 01
4. Stereo PLCC-2 SMD White 3.5v rest all white 07
PLCC-2 SMD Blue 3.5v Disc, XM, AM/FM, Mode 03
5. Heater Switch 3mm with adaptor White 12v/3.5 not changing Hi/Lo indicator 02
6. Both Rear Door 3mm without adaptor Blue 12v/3.5 Door handle and storage console 04
3mm without adaptor White 12v/3.5 both window switch 02
7. Driver Door 3mm without adaptor Blue 12v/3.5 Door handle and storage console 02 PLCC-2 SMD White 3.5v All four Window Switch 04
PLCC-2 SMD Blue 3.5v pass. Window on/off switch 01
3mm without adaptor White 3.5v lock / unlock 02
3mm with adaptor white 12v/3.5 Number 1 & 2 on memory SW 02
3mm with adaptor Blue 12v/3.5 Memory 01
8. Pass Door 3mm without adaptor Blue 12v/3.5v Door handle and storage console 02
3mm without adaptor white 3.5v lock / unlock 02
PLCC-2 SMD White 3.5v Windows Switch 01
9. Gage control 3mm with adaptor white 12v/3.5v < info> & + brightness - 02
3mm with adaptor Blue 12v/3.5v Select/ MAX 02
10 Steering Wheel 3mm with adaptor white 12v/3.5v Cancel, vol, CH, set-reset, 03
3mm with adaptor White 12v/3.5v HLF buttons (call & end) 02
3mm with adaptor blue 12v/3.5v Mode, Cruse 02
11. Mirror/Trunk 3mm with adaptor Blue 12v/3.5v Trunk release 01
3mm with adaptor White 12v/3.5v VSA 01
3mm without adaptor White 12v/3.5v Mirror 01
Total Bulbs:
White 12v for direct use or 3.5v with resistor 22pcs (with Adaptor)
12v for direct use or 3.5v with resistor 04pcs (without Adaptor)
PLCC-2 Type 3.5v 12pcs
3mm round 3.5v Only (I will use SMD) 04pcs
Blue 12v for direct use or 3.5v with resistor 07pcs (with Adaptor)
12v for direct use or 3.5v with resistor 08pcs (without Adaptor)
PLCC-2 Type 3.5v 07pcs
Blue
Total Bulbs:
Blue
Total Bulbs:
Blue
Total Bulbs:
Mons shaver
Maybe links would be helpful.
I'm not very verse in LEDs, but I've been searching by 194-168 numbers for most of the interior bulbs (dome, vanity, doors). I'm sure you are talking about the same thing, but since I'm not very familiar with the terms, those numbers are all I can search by.
the lights located in the driver side power window switch and the passenger side window switch... etc
09-17-2015 09:01 PM
