Display with Navi (always on?)
Old May 21, 2004 | 10:29 AM
D4SSWME's Avatar
newbie here.
is there a way to turn off the display of the navigation when in radio, tape or disc mode.
the light from the display screen is kinda bright when driving at night
thanks!
Old May 21, 2004 | 10:32 AM
Jss1's Avatar
Originally Posted by D4SSWME
newbie here.
thanks!
Go to setup. Say "Display off", or touch the display off icon.
Old May 21, 2004 | 10:40 AM
J RIDE 81's Avatar
Team Nighthawk Director
Put the screan in night mode. Shouldn't be too bright after that either. You can also leave the screan off by not pressing "ok" when you turn on your car. Hope that helps a little.
Old May 21, 2004 | 11:04 AM
gvahe's Avatar
You max also have "Max" selected on the instrument cluster. (where the +/- buttons are to adjust your instrument panel brightness)
This puts EVERYTHING to max brighness (Including the NAV display...takes it out of night mode )
Old May 21, 2004 | 01:08 PM
Step one.............speak, "Display Setup"
Nav responds.................."what do you want to setup?"
You now get even with it and say ......."display off"
Poof.....it vanishes faster than the nose shake on Bewitched!
Old May 21, 2004 | 04:39 PM
hmdsc's Avatar
Team Anthracite Member
Maybe try black spray paint? I hear that works well. :enforcer:
Old May 21, 2004 | 05:25 PM
D4SSWME's Avatar
you first!
hmdsc,
let me see how the black paint works on your first before I make up my mind in following your suggestion (heh heh)
Old May 21, 2004 | 09:50 PM
ibeplato's Avatar
i just press the "audio" button. I mostly use the touch screen to control the radio, I figure since 99% of my driving is to work & back I don't need the map anymore. :-)
(however, it is that other 1% when nav kicks ass.)
Old May 22, 2004 | 12:02 AM
TonySCV's Avatar
Speaking of that... what is the voice command to pull up the audio menu from the map screen? I can't find it for the life of me.
Old May 22, 2004 | 12:47 AM
Lore's Avatar
CEO, Team Anthracite
I do not believe there is one.
Old May 22, 2004 | 07:33 AM
smoore's Avatar
Lore is right. You cannot call up the audio screen with voice command.
ITSJESTER
17
Dec 6, 2018 02:29 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
Froid
Sep 27, 2015 06:16 PM
Cgannotti
Sep 25, 2015 05:04 PM
