Disable DRLs?
Disable DRLs?
hey all,
just bought a 07 TL a few months ago, had a 07 corolla s before that. disabled the DRLs for the corolla and loved it! anyone know of anything or how to go about that for the TL?
thanks!
thanks!
Enthusiast
I know in my Honda Fit, all I had to do was remove the DRL fuse in the fuse box next to your feet. If Acura is the same, just figure out which is the DRL fuse and remove it. Should work.
Balling in the...
Yea if you don't care about the DRL Warning on the Dash, that would be your best bet. Unless you remove the bulbs which involved removing the from bumper but this might trigger the warning light as well. I think you should leave them alone and just put some LED bulbs in them and call it a day. No Warning lights and no ugly Halogen bulbs to look at...
This is what im doing
2014 Jeep SRT
Pull fuse #3 under the dash. Unless the "DRL" light freaks you out, this is what I'd do. I'm not a big DRL fan.
UA7 NBP TL-S
Pull the DRL fuse or remove the bulbs.
Add 2ohm 50watt load resistors on each side of the bulbs connection, no DRL error on dash. You can get em here they are plug and play with your stock harness for the DRL.... https://acurazine.com/forums/forumdisplay.php?f=93
btw I have mine so I can turn mine on and off and love that set up....
UA7 NBP TL-S
^sorry my browser tweaked out and copied the wrong link... here is what you need... ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
http://www.v-leds.com/BlinkerWarning...85827-1-3.html
UA7 NBP TL-S
and if they are out of stock than get these..
you would have to splice them in into your stock connection which is no biggie, but its a cheap fix
Enthusiast
I am not certain that the light will even come on after you remove the fuse. However, it WILL come on if you remove the bulbs. I suggest you just give it a whirl and find our for yourself. If the light does come on, just pop the fuse back in. Good Luck
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
joflewbyu2
10-08-2015 11:16 AM
