Daytime Running Lights
Originally Posted by daviddww
I have never once driven without my headlights on...sun, rain, day or night. Not only does it definately increase your visibility to other drivers, but the car looks so damn cool with the headlights on!
I hear what you guys are saying, and I agree that in less than optimal conditions that the headlights should be on. But on nice days, turn the damn things off. They don't help, and only make things worse...
Originally Posted by EpiK
Not looking for a flame war, but when they initially came out, my first impression was "Look at the idiot who left his lights on..."
Originally Posted by crazymjb
Aight, forget it then. Screw whoever gets in my way. Ill just drive at high RPMs so maybe they can hear it?! Jeez thats steep for a bulb replacement. Is it covered under the initial warrenty, or is normal ware?
They still cut into my lane like no one is there.
Lots of drivers really should be banned from the road.
Good luck on daytime mod though. I would do it if i didn't have HID fogs. Cuz of that, i manually turn on my fog+corner mod after i start the car to protect the bulbs.
Originally Posted by triggle
The TL should have used these as a compliment to the LED tails then you'd all be singing the praises of DRLs.
Guy: "Gee Martha, why is it all of a sudden I can't see out the windsheld?"
Wife: "It's raining, you moron!"
Fortunately, GM has backed off the stupid idea and newer models run the parking lights instead of brights. Don't get me wrong, I ride a motorcycle as well and the lights (not hi beams) are always on. I added some halogen lights to the lower fork for added visibility. If you need to run your lights, then just turn them on!
rw
Originally Posted by sparky57
Not a chance. If you're incapable of remembering to turn on your lights when needed, then you shouldn't be driving. I feel the same way about automatic wipers.
Except there's something to be said for convenience. Also, up where I live, you should have running lights on at all times. It makes sense to have automatic DRLs, that way my life doesn't depend on someone forgetting to turn their lights on. There's an idealized world where everyone would remember, and then there's reality.
However the whole DRL argument seems to be based on the fact that people in the US who simulate DRLs by using their normal headlights... or car makers are shoving bright lights in as DRLs. This, I can understand being a problem. The thing about DRLs is, properly implemented, they're not the same as having your head lights on.
DRLs are supposed to be 'running lights' visible to anyone looking at the front of your car, same as any other running light on your vehicle. They are supposed to be much less intense than normal headlights. In many cases, DRLs are completely separate lights, and even coloured differently from headlights. The goal is to have emissive elements on the front of the car, instead of depending on reflected light. This improves visibility, even in sunlight.
If someone's DRLs are blinding you, they need to get them fixed, or they need to stop running their headlights to fill in as DRLs. Proper DRLs don't blind you, they just help you notice cars better. I fail to see how one can argue against a feature that improves visibility of oncoming traffic, any more than one can argue against turn signals. Someone should tell the car manufacturers to use illumination strengths that don't dazzle people, since that's counterproductive to the intent.
I simply don't get dazzled driving around in Canada during the day.
Probably the strongest argument against DRLs is that once most cars have DRLs, cars without them are actually even harder to see (drivers and pedestrians get conditioned to looking for lights rather than cars). However even at that there's a 10-11% reduction, depending on study, in head-on collisions due to the technology.
Where DRLs are most useful is in rural or urban two-lane traffic, where the risk of being hit by an oncoming vehicle is greater. Where they are not nearly as useful is on divided highways.
I also agree with earlier posters, that if you have front running lights, they should also have rear running lights.
Proper DRLs don't blind you, they just help you notice cars better. ..Someone should tell the car manufacturers to use illumination strengths that don't dazzle people, since that's counterproductive to the intent.
If someone wants to pay for automatic lights or wipers, then so be it.
rw
What I object to getting subjected to brights in my face.
As for being on all the time, most (if not all) DRL implementations here run the brights at half intensity.
Some, I'm sure, are better designed than others for the level of possible interference with oncoming drivers, but that doesn't make DRLs useless, it simply means some implementations have flaws.
It sounds like your DRLs are fundamentally different from the ones found in the states. Here they are the high beams which are aimed much higher than the normal lights, lowered intensity or not.
This may change if DRL systems get brighter (I'm not sure what the regulation on brightness is for them)... or if car lights just get brighter overall with HIDs and the like.
The only such beneficial study (Canada has never done one)
from Norway where the ambient lighting is quite different from what you find in Atlanta, GA
I guess my final thoughts on the matter are that I see DRLs as being valuable safety equipment, but they do have to be designed with some sense. The idea is to make your car glow a bit to be visible, not to replicate the function of your high beams. I also think DRLs need to have rear-visible lights as well, for the jokers that don't turn on normal lights during the rain.
(In fact, the argument about getting dazzled by bright lights affects me fairly often in the rain, compared to driving around in decent weather, because people actually turn on their headlights, which are much, much brighter than the average DRL here)
Originally Posted by SouthernBoy
A great man once said, "Those who give up essential liberty for temporary safety deserve neither liberty nor safety". (Benjamin Franklin, 1759).
As I said, when there are maybe 5% of the cars and trucks on the road with DRL's during daylight hours, yoy are certainly going to notice them. But if, due to regulation, those numbers rose to 90%+, then they're just all going to look like the next guy.
Small prices to pay soon become large costs to bear. Witness the erosion of our Second Amendment rights just to name one. Or the absolutely ridiculous warning labels on so many household products. At what point to we say enough of this nonsense.. we know what's best for us?
Now, I don't at all mean to equate the "privilege" of driving with the "right" to bear arms. One is indeed a privilege and one is an absolute cast-in-stone right. Big difference. But some of our representatives are so far off base, you have to wonder about their sanity.
Repecat.. if you want to use your headlamps during the daytime, then by all means you should do just that. And if you believe it makes you safer, go ahead and have at it.
This is too funny, people getting upset over DRL!
First off, DRLs help other people notice your vehicle sooner - that is a fact! All new model motorcycles are required to have DRLs, why? so they are seen sooner. I ride and am glad my light is on all the time, I already have too many schmucks pulling out in front of me with the light on all the time... and no I don't speed too much on my HOG.
Second, people driving with their regular lights on during the day might blind you ...not DRLs.
Thirdly, fog lights are for when there is fog, not to help you see better at night. This pisses me off the most when all the SUVs drive with their fog lights on all the time, in Germany you can get a ticket if you have them on when there is no fog... that is why they are called fog lights!
:-) I just had to get that off my chest... yes, I feel better now.
btw ... I guess the original question is dead ... there is no way to mod the lights for DRL...
Canada's done at least two that I can find references to on a quick Google search. One found an 11% reduction, the other a 15% reduction. The latter was 28% reduction if you focused only on head on or side impacts where the lights would be visible.
http://www.tc.gc.ca/roadsafety/stats/menu.htm
Is this where your 11% "proof" originates?
http://www.tc.gc.ca/road/faq.htm
or here? (scroll down a bit)
http://www.ibiblio.org/rdu/DRLs/studies.htm
If so, please note the word "estimate" used in all these references. Why is that? Obviously, any such study would necessarily have to make assumptions as to how many people with non-DRL vehicles do or don't turn on their lights when they should. If a non-DRL car is involved in an accident, how do you know whether or not their lights were on? Whatever.
The current implementation of vehicles in the states is poorly designed and irritating. Fortunately, our studies (using actual data) and that of Japan have concluded there are significant problems, especially masking issues for motorcyclists.
rw
rw
Studies here, in the UK, and in Japan have concluded that DRL use in automobiles reduces the effectiveness of lights for use with motorcycles.
Please explain how low beams are more blinding that high beams (look at any older GM vehicle)
Ths solution was provided with one of the first posts - just leave your lights on. They automatically shut off. Unlike DRLs, they run all the lights, not just the high beams.
rw
rw
What are you saying? That light on motorcycles do not help them in being seen?!? Or that if all the cars have their lights on it washes out the cycles ... DRLs still help cars in being spotted sooner, as studies in Germany have shown.
I never said that low beams are more blinding than highs, I said, "Second, people driving with their regular lights on during the day might blind you ...not DRLs." That went to the dude who said the DRLs blind him, he is probably talking about the regular beams and not DRLs ...I didn't even mention high beams.
And the solution to the mod was never really posted, as in rewiring the system to allow for DRLs; driving with your lights on is a work around that blinds/ annoys other drivers. Yes I drive with the lights on all the time, but I wish the TL had DRLs. As an EE there must be a way to wire the fogs as DRLs or the highs in series ... if I only had a schematic/wiring diagram. Where there's a will there's a way.
What are you saying? ... Or that if all the cars have their lights on it washes out the cycles ...
...driving with your lights on is a work around that blinds/ annoys other drivers.
rw
If you are not proposing using your lights as the Daytime Running Lights, then what is your idea?
rw
To jdone;
Of course I've long heard the argument for having people wear seat belts because it lowers insurance and costs for everyone. But we could apply that same logic to smoking (which it is already, anyway) or a host of other things. Why not do this. If someone had an accident and they're at fault (say with a tree) and it can be shown that they were not wearing a seat belt, then the insurance company doesn't have to pay. The guy loses everything for his negligence. Talk about hitting someone in their wallet! I know this won't fly, but it raises the issue of ultimate responsibility, doesn't it?
Life isn't always fair and to be really free means you have the freedom to not only do the best you can, but also to fail.
Back in the day installing a switch to only have the front lights on was easy enough to do ... but I don't know what it would take with the newer cars.
rw
Relax. LED based taillights and side markers are both energy efficient and long lasting.
rw
rw
Energy was never a concern. My point was that it was easy enough to wire up new configurations, since the wiring and the access both were simple. You know the more I think about it, running with your regular lights on is the best solution, it is really not worth the hassle of tearing stuff apart and rewiring things just to have DRLs. Yes they would be nice, but I'll just leave my lights on all the time. I am surprised the TL does not have the automatic lights on when it gets dark feature... even my Sable has it!
I don't really think that DRLs are nessessary. I would never use them. When it is raining or if it is Dusk or Dawn, then you can put your lights on. Why would you want your lights on during a sunny day? You wouldn't be able to see them. But hey, if you want people to see you, just drive with your parking lights, or your fogs.
To jdone;
too funny.
in the south, what you call "running lights"
are called "PARKING lights"
as in... turn these on when you are NOT MOVING
LMAO.
anyway, i concur with those that say the TL should have DRL's. they DO work.
doug
LMAO.
doug
A fact is DRL reduces accidents. Everyone has DRL and it really helps you to judge distance of oncoming and traffic behind you.
I was traveling Montata and Idaho over weekend and I saw signs saying "Please use headlight for safety" or something like that.
I can see DRL will be mandated in States soon.
In night, DRL does almost nothing to illuminate road. You will know right away if you are missing HID.
Originally Posted by batdude
too funny.
LMAO.
doug
LMAO.
doug
What a resurrection of an old thread!
Just made my Fogs double as DRLs
Sorry I don't have pictures yet. I just got done installing a daytime running light module. It makes the fog lights come on at 75% intentisy when ever the car is turned on. My headlightsand fog lights still work normally. I used to just ride around with my headlights on all the time, but now I don't have to. I am very pleased with how this turned out.
The company's name is Ignitoin Systems Inc.
They have a couple to choose from. The one I got was 38.50 with 4.95 shipping and handeling. It took all of about 20 minutes to install. It is not intrusive and you don't have to cut any of the cars wires.
http://www.automotiveelectronicaccessories.com/
I believe this is the module you purchased? http://www.automotiveelectronicacces...aeapn480hd.htm
Good thing is that it appears to be universal
Studies I've read show that cars with DRL's have actually been involved in more crashes that similar cars without. DRL's also waste fuel.
I personally don't like them, but if people want to have them that's fine by me... I just don't want them made mandatory.
You are right that is the one that I purchased. Thanks for fixing that web address.
Corvette style DRL's
Have you ever seen a corvette especially in ur rear view mirror during the daytime and its got that creepy look to it. Ofcourse it's the body style and everything too but I also think it's the bright yellow/orange DRL's that r close to the ground right on the side edges of the front bumper (they even wrap around a little bit). I have always wondered how that would look on my Black Baby and they r definitely noticeable.
and yes I do want light sensors that my corolla had that would make the headlamps come on when it got dark not cause I am lazy but because all this technology should be in a luxury automobile including rain sensing wipers.
To ntaylor;
We have seat belt and child safety seat laws here in Virginia which I find repugnant. More extreme cases of regulation into the private lives and business of people are smoking bans in public places.
As for the child safety laws, I can't imagine how you can disagree with that!? Children depend on adults to provide protection for them, and the best protection available right now are child car seats (and boosters). It amazes me how many people still don't properly fasten their children in car seats even with these laws in place. Believe me, I understand how inconvenient they are - I'm the father of 3 currently in car seats with twins on the way. And, yes, I know that our parents let us jump around the car while traveling 70mph and we're still here...
For the smoking thing, I would have no problem with smokers if they just inhaled all the smoke. The problem I have is that I am inhaling some of their smoke. And yes, when I'm out in public, I'm still breathing in the smoke if they're smoking withing about 15 feet of me. So, the actions of smokers are infringing on my right to clean air.
As for regulating DRLs, I can't imagine how this would bother anyone. As mentioned previously, proper running DRLs would never blind anyone, and would be nothing but good for overall driving safety.
I believe in freedom, but I also believe in doing what is in the best interest of everyone. Common sense is not all that common. Sometimes people need some incentive to do logical things.
I'm not questioning your recollection. I remember the study as well. I simply flat out don't buy it. The study was done by the car manufacturers - the same ones who needed a new "safety feature" to add to their cars after a few years of stagnation. First came air bags and anti-lock brakes, but with the Japanese invasion of the mid-80's the American Companies began needing to cut costs while still giving the impression of improved safety. Hence the big new safety feature of the late '80s: Driving with your headlights on!
And I don't mean to be confrontational - I'm certainly not arguing having lights on at dusk or in the rain. My problem stems entirely from those with their lights on at noon on a perfectly sunny day...
BTW the study originally was done by the Swedish insurance associations with follow up studies done by insurance and safety organizations in other countries including north america. Not the car manufacturers.
References Studies
[QUOTE=bluenoise]Good find! Can you please explain which wires you tapped in order to connect this thing?[/QU
I tapped into the left fog light. The blue wire with yellow stripe is the positive side. The black wire is the ground. Then there is a hot wire that goes to the positve side of the battery. The last wire needs a key on feed. I didn't want to go thru the fire wall so I found that the yellow wire in the windshield wiper motor harness worked well for this.
Originally Posted by missmyprelude
Although I agree with your rant about seat belt laws, I do understand why they have been inacted - idiots that don't wear seat belts cost those of us that do money. I've always worn mine (before and since they've inacted these laws), so it doesn't matter much to me. If it makes more people wear them, then it's all good to me.
I give up on the rest of society... they wouldn't see you even if you waved a red flag in their face.
