Daylight savings TL onboard clock?!
tehLEGOman
Received 1,983 Likes
Hello fellow acuraziners!
Just returned from the sunshine state on vacation and was wondering if anyone else's onboard clock didn't automatically change. If I recall correctly, it has changed automatically before...unless i'm crazy. I've had the TL for almost 3 years now, and don't remember ever having to change the clock.
Let me know if i'm crazy. thanks!
Since Daylight Savings Time has been moved up a month, I'm betting the programming is incorrect. Just wait for a month and the clock will jump ahead 1 hour....when you don't want it to....he he.
I have a weather station and this is the first time it didn't change automatically. The Feds have screwed up DST.
Gratis dictum
You win the bet! The clock won't change by itself at this time; you will have to manually set it ahead one hour. Then, in 3 weeks, you will have to set it back one hour as it will automatically adjust at that time. I understand that Honda is working on a fix, but that probably won't be available until fall.
~Da Nocturnal Cheetah~
You can always do as someone else suggested and merely de-activate it and set it manually until you get the patch! That's what I am going to do. Then you only have to do it once!
Sorry guys. There is already a discussion here: DST Patches
edit:
and here: DST Issue Service News Article from HONDA
edit:
