Custom Tail Lights and Head Lights by AckTL05
rockstar143 (04-25-2013)
#1123
awwww...shiettt...
Thanks for the shout, bud...great execution.
Mine are currently under construction, not sure why but my right clear lens has these huge spiderweb cracks that come and go depending on weather? I plan to fix it.
Don't worry, I made them myself, Bruce's are immaculate.
Recently did a similar treatment on a set of base reds to see how they looked, another option for the oem look, on a budget...not as pronounced but looks cool, I think.
Sharing for Bruce, I know you've done similar, but in case someone likes it.
OEM left, modded right. CF on reflector, black gloss bezel and frosted diffuser gone
http://www.flickr.com/photos/rockstar143/8661138321/http://www.flickr.com/photos/rockstar143/8661138321/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/8661138489/http://www.flickr.com/photos/rockstar143/8661138489/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/8662237440/http://www.flickr.com/photos/rockstar143/8662237440/ by http://www.flickr.com/people/rockstar143/, on Flickr
http://www.flickr.com/photos/rockstar143/8661138899/http://www.flickr.com/photos/rockstar143/8661138899/ by http://www.flickr.com/people/rockstar143/, on Flickr
MEKO (04-29-2013)
#1128
just installed these for a customer. He had DEPO headlights and when removed, they literally were dripping water out and the halos were faulty.
We found him a set of OEM headlights/installed supplied halos and my custom wiring harness for the halos to have a switch for them. Blacked out V2 with carbon fiber sides and ZKW-R lens:
The following 3 users liked this post by AckTL05:
#1129
had JnC do my halos before I saw your work, he told me he couldnt do quads on mine because of my fogs and that they will melt over time... do you agree? or care you able to do quad halos on 06 oems
#1130
Ohhh I missed here J.
So it's just the stock tails with black bezel.. which is what I wanted, but I love the oem look that I just can't make Bruce touch them
+ I want rockstar tails too
#1131
i never understood why ACURA put the fogs in the same projection beam as our already powerful projectors..
To install these dual halos on 04-06 its pretty complicated/time consuming and I have to make custom brackets to hold them/run the wires..To this date, I can count maybe 7-8 sets i've done with the dual halos on the 04-06 TLs.
The following 2 users liked this post by AckTL05:
MEKO (04-29-2013),
rockstar143 (04-29-2013)
MEKO (04-29-2013)
#1133
J the subtle reds are sick.
#1134
I would use LED bulb for the upper fog with halos
It'll look sick and no heat-up
#1135
Thanks Chad,
Cheap to be had since base reds are everywhere...and just what you dig, slightly modded OEM look.
Meko, yes sir, LED all the way, keep the heat down.
J.
Not trying to threadjack, just like to show other options for Bruce to be able to make for members.
http://www.flickr.com/photos/rockstar143/8689707084/http://www.flickr.com/photos/rockstar143/8689707084/ by http://www.flickr.com/people/rockstar143/, on Flickr
J.
The following 2 users liked this post by rockstar143:
maharajamd (04-29-2013),
MEKO (04-29-2013)
#1136
^That is EXACTLY what I want.
#1138
^Already PMed Bruce.
I'd do it myself but I'd have to track down a set of base tails. I'm hoping he has a spare set to sell/trade-in.
rockstar143 (04-30-2013)
#1144
Thanks everyone...
ironically, the cracked/chipped right side type s modded one leaked today, never happened in the last six months so I'll finally get around to fixing that. For now, I'm frankensteining it and rocking 2 different tails...
#1145
once paid, depending upon the day of the week paid, its 2-3 days max and they will be sent out. Also depends if you order color matched paint which I would have to wait for, halos, any special item/design. The normal blacking out though takes 2-3 days give or take once paid.
Send me a text I will help with that leaking problem...
rockstar143 (05-03-2013)
#1146
Another master piece of AckTL05. Loving my new heads and tails. Need new led switchback signal
http://www.flickr.com/photos/95430797@N03/8702984535/http://www.flickr.com/photos/95430797@N03/8702984535/ by http://www.flickr.com/people/95430797@N03/, on Flickr
http://www.flickr.com/photos/95430797@N03/8702984823/http://www.flickr.com/photos/95430797@N03/8702984823/ by http://www.flickr.com/people/95430797@N03/, on Flickr
http://www.flickr.com/photos/95430797@N03/8702985777/http://www.flickr.com/photos/95430797@N03/8702985777/ by http://www.flickr.com/people/95430797@N03/, on Flickr
#1147
MEKO, why'd you quote without saying anything?
Bruce, will do, brother. Thanks. Well, I wasn't sweating it much, because that's the same tail with:
1) corner chipped, found and glued on (thanks fedex!)
2) lens gets these long cracks that come and go
3) water inside, but will call you to see how to combat that, I've never had an issue with that before.
Yesterday, opened my first set of depos and what a PITA! Cheap plastic slags worse...and basically seals the bezel in until you go back around and cut it out.
Do you like me sharing ideas/pictures here, Bruce? I just do it to show other options in case someone wants to pay you to do them.
MEKO (05-03-2013)
#1149
Oh he did edit the link for the pictures
Can mod delete? hehe
#1154
#1157
Here's one I made...I never liked how dark the signal areas were on the depo smoked tails...so I chromed out inside there, then did the "rockstar" treatment on them. I made red lenses out of the clears out of my original base reds, bezel was already matte black, and removed frosted diffuser.
They're basically a darker version of the original ones I made.
http://www.flickr.com/photos/rockstar143/8715309353/http://www.flickr.com/photos/rockstar143/8715309353/ by http://www.flickr.com/people/rockstar143/, on Flickr
#1160
I actually do a 4 step seal process to ensure no gaps/holes which can cause leaks. One of the sealants steps I created myself and it can't be bought anywhere. Basically need glue and make sure it's sealed, I've seen things used from hit glue gun to superglue.
rockstar143 (05-11-2013)
