Collison shop wants to "mix" paint to match AM
Ok well the wife try's to snake it out the driveway and swipes my work car, a Ford Focus
https://skydrive.live.com/redir.aspx?cid=c4ace818d46fb013&resid=C4ACE818D46F B013!351&parid=C4ACE818D46FB013!151&authkey=!AD-pTqjsyT1EJbI
I got a quote of 1102 dollars for the repair
but I asked the guys at the shop if they use OEM paint, their reply was "No OEM paint isn't available to the market". I haven't had time to research that comment, but it sounds like BS. What do you think?
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
TL-S
Most places mix paint...as long as its quality paint (PPG brand) its fine. They mix a few different batches and pick the closest to the car to get the best match.
Nothing wrong with that...my cars been in the shop twice in the last year and this is ye procedure they used. It matches perfect DGP.
ABP_04TL (01-13-2012)
3G TL/2G MDX Owner
the $$ amount for the damages is about right. they have to repair any indentations incurred, then blend paint to the door, the rear quarter and the rear side skirt.
if you find a shop that works on acura's all the time, with a good track record...the shop should not have a hard time matching the paint.
i had some damage to my rear quarter by the door years ago from a hit and run (softball sized dent with paint scrapes), that was almost $1000 to repair.
get a few more estimates from other shops and see what they say.
sorry about the car. good luck.
Honda doesn't produce automotive paint, nor do they retail paint for bodyshops. They use a supplier. The big chemical companies in the US auto paint market are PPG, Dupont, and BASF. Honda probably uses a brand line from one of these guys. Most quality bodyshops use one of these same companies. Auto paint in a brand product line is supplied in an array of tints. The different tints are used to mix the paint at the shops by paint code. When a painter enters a paint code in the mixing system, it generates a list of color variants to select from, including a standard variant. Shops select a particular variant that best matches the color on the actual car. If they have to, they can adjust the color or by tweaking the mixture of tints.
I will say from experience with BASF RM Diamont. When AM first came out as a color offering, it was/is a tough color to match. If panels are being color blended its not so much of an issue. But, when painting AM bumpers it takes time to ensure an acceptable match to the adjacent panels.
If they're reputable as someone said they should be able to do it right, assuming their painters or assistants are competent enough to do it right + blending. Panel painting with mixed paints never comes out right IMO.
Mr. Detail
Actually, they don't have the actual OEM paint the factory uses because the painting and baking process is different. The paints body shops use are specially formulated for refinishing and a lower baking temperature.
Don't worry so much about best price, if that is all you focus on you are not going to end up happy with the work. Cheap paint/body means they skip steps like proper prep, removing molding, lights, etc and just tape everything. Lower quality primers and paints, the list goes on.
DerrickW
11-15-2015 05:52 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
