coasting in neutral
Old Jun 25, 2008 | 04:30 PM
  #41
SouthernBoy's Avatar
Registered Member
Originally Posted by stillhere153
if you do not listen to the above posted and still do it... and you leave ur foot on the clutch = premature clutch wear...
If the clutch is fully disengaged while doing this, there is no wear at all on the clutch assembly. However, the release bearing, and to a small degree, the release fork will experience a shorter life.
Old Jun 25, 2008 | 04:33 PM
  #42
Registered Member
Originally Posted by o4Komodo
So.. theoretically, putting a 6spd out of gear and into neutral at a red light would waste more gas where-as to leaving it in gear? I think I'd rather waste gas than wear out the clutch by holding it down for 30seconds to a minute at each light.
And to tzarchasm, I don't completely see anything wrong with going into neutral once the car is in motion [for a 6spd]... I see it done all the time and I admit that I do it to sometimes. And it's not that hard to enage back into a gear--as opposed to the 5AT.
You should always take your car out of gear and into neutral with your clutch fully engaged (foot completely off of the pedal) when sitting at a traffic light (red). The reason is to reduce wear on the release bearing.
I don't quite understand your statement, "I don't completely see anything wrong with going into neutral once the car is in motion [for a 6spd]". I would have to ask why would someone want to go into neutral after getting the car in motion.
Old Jun 25, 2008 | 04:37 PM
  #43
Registered Member
Originally Posted by grsd03
thanks for the post guys, i agree about the brake prematurely wearing out due to no help from the transmission. However if you are not going to be coming to a stop for example on the highway and you are on a highway full of hills can't you just neutral coast down them? I know there is a safety issue just curious about what an article i read and a conversation with a co worker.
As for the fuel cut off when your off the gas but in gear, that will cause the car to slow down so your still going to have to apply some gas in order to get the car going at the correct speed.
Also i've been told to coast to lights when coming to a stop instead of downshifting to prolong the life of my clutch so isn't this essentially the same thing?
Any more thoughts?
The individual who told you this clearly does not know how to properly downshift. So I would say that if you do not know how to downshift correctly, then avoid it as much as possible.
Old Jun 25, 2008 | 07:55 PM
  #44
Babnik's Avatar
People, I am surprised by the complete lack of knowledge you have (not all of you, some of you) about how manual transmissions work. How in the world are you putting MORE wear and tear on your transmission by coasting in neutral? Can all the people who claimed that please provide an explanation of the mechanics of it so that I can understand why you think this is the case?
The fact is, you are ALWAYS putting LESS wear on a manual car when it is in neutral than when it is in gear!!
So yes, you will save both fuel and wear on your clutch by coasting to a light.
The only part you are saving wear on by downshifting is your brakes, but transmissions are more expensive than brakes, so it makes no sense to save your brakes at the expense of your transmission. Besides, people who have automatics have to use their brakes like that anyways.
At the very least, your car should always be in neutral when you are sitting at a red light, unless you know the light will change very soon, the wear and tear caused by shifting it into neutral then back into 1st will exceed the wear from keeping it in gear for a few seconds, so in that case it's ok, but if the light is long then always put it in neutral.
The only way I am wrong is if the TL has some completely new transmission design that I am not aware of, in which case I am happy to admit I was mistaken, but I doubt that is the case.
Old Jun 25, 2008 | 09:19 PM
  #45
Registered Member
Downshifting, even not done correctly, has little effect on the transmission as a whole. On the other hand, the synchronizers are exposed to added wear when downshifting incorrectly.
Your statement about being in neutral when at a light unless the wait is short is correct. But again, it's not the transmission that gets the wear here.. its the release bearing unless one is continually taking it in and out of gear with the clutch engaged and then disengaged in which case the synchronizers get added wear.
Here's a little hint when sitting at a light or stop sign. When you are ready to engage first gear, start the shifter into third first and then go into first gear. This is much better for the first gear synchronizers.
Old Jun 26, 2008 | 02:30 AM
  #46
o4Komodo's Avatar
Rev High; Drive Happy
Yeah, at red lights I'm always out of gear. I always fully clutch in--and when at a stop my foot is off the clutch, just incase.
As the other comment, well--I know a lot of people who see a red light coming up and drop out of the gear and coast in neutral to a stop.
Old Jun 26, 2008 | 04:48 AM
  #47
Registered Member
This is Ok when done "at the last moment". In other words, close to making your full stop. I wouldn't recommend it when you're 100+ yards back and still traveling, say, 35 MPH. I do this myself frequently as I approach the light but pretty much when I am within seconds of getting there.
Old Jun 26, 2008 | 07:44 AM
  #48
TzarChasm's Avatar
Well I tried to explain the physics, but unless I get a lot more complicated, I can't prove it. And I am 99% sure that even if I did prove it in a mathmatical equasion, those of you who insist on coasting in neutral are not going to believe it anyway, since you cant understand the math in the first place. Therefore I am not going to waste my time, if you think coasting in neutral is going to save you some gas, go for it. It's not going to, but if it makes you feel better, who am I to argue?
I don't really have any idea about it's effect on the clutch, I speculated it might not be good, butI know a lot more about physics than I do mechanical engineering, so I'll leave that part to people who know more than I do.
Old Jun 26, 2008 | 08:06 AM
  #49
TeknoKing's Avatar
I perfectly understand what you guys are saying, coasting neutral when approaching a stop light, I've done that plenty in OLD m/t cars...(Babnik)
Your TL was designed with gas saving in mind. The ECU/PCM is a VERY smart computer. You do not need to use old tactics for maximum fuel savings... The best thing you can do is to always stay in the right gear per mph/rpm. This is your best bet on saving gas.
I still throw in neutral when I need to come a complete stop, before throwing in reverse, not forward gears.
Of course everything I say are just my opinions, you may do as wish, or in fact, experiment one week driving differently, you can only prove this to yourself as of what really works for your style of driving.
Old Jun 26, 2008 | 08:07 AM
  #50
TeknoKing's Avatar
Yes those things are cheap to replace, but it's a hassle.
SidhuSaaB
May 30, 2020 12:40 AM
Aug 15, 2019 12:58 PM
Gary3N
5G TLX Problems & Fixes
35
Feb 25, 2016 06:31 PM
DerrickW
Nov 15, 2015 05:52 PM
MikeJM310
Sep 24, 2015 07:24 PM
