clutch bypass
On DEI models, run the -200mA starter output wire (on the viper 5901, python 991, and clifford 50.7x, it was in the remote start aux output harness) to the light green wire of the clutch interlock switch on the clutch pedal. There are two switches on the clutch pedal: the clutch pedal position switch (lower switch, doesn't have green wire) and the clutch interlock switch (upper switch, has green wire), be sure you get the correct one. You should diode isolate this wire.
FYI, there is some discussing of this in the audio forum, but a great source of this type of information can be found at the12volt.com car security and convenience forum:
SidhuSaaB
05-30-2020 12:40 AM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
