Clearing headlights question....
Old Feb 17, 2009 | 03:57 AM
nokiaboy808's Avatar
06 6spd TL BAGGED
This is for anyone who has cleared their own headlights or took them apart..
Did you have trouble aligning them up again when sealing them back?
The question is because i'm in the process of sealing my headlights back up and the first headlight i did doesn't sit flush like how it was before i opened them up. Also most of the plastic tabs don't go over the plastic lens. Is this normal after opening?
Old Feb 17, 2009 | 04:01 AM
AnthraciteAspec's Avatar
RPF1+RS3 FTW
This happened to me, they did not line up for shit and I had all kinds of gaps. Thus I am sending a set to JnC to have them done professionaly. That and JnC helped get me some clear diffusers and I want those in.
Old Feb 17, 2009 | 04:15 AM
powerflow's Avatar
Wiggy Wiggy Wiggy
No, it's not normal. Should be flush, and tabs should be back in place.
I used a bunch of small vice grips to pinch the edges together, along with a heat gun. Worked like a charm.
Old Feb 17, 2009 | 04:51 AM
06 6spd TL BAGGED
ahh ok. a heat gun would really come in handy! so i just ended up adding silicon all around the edges. hopefully it holds up... anyone else has any input to this?
Old Feb 17, 2009 | 05:01 AM
JD TL-S's Avatar
OH BOY. I was going to have JnC do mine also, then figured I could do it easily?
Now I am getting nervous again?
I ordered a pair of Angel Eyes and now wonder if they will be a problem?
I read on another thread that they come unglued easily? DARN-IT. WTF.
Sorry. ?
Old Feb 17, 2009 | 06:16 AM
06 6spd TL BAGGED
Sorry. ?
i used a thin wire to hold mines in place just in case, but they are snug between the bezel so it shouldn't be a problem for me.
Old Feb 17, 2009 | 06:47 AM
powerflow's Avatar
Wiggy Wiggy Wiggy
I wouldn't expect the light to seal. Using a little extra rubber butyl is the way to go, with the heat gun and many vice grips. Keep the edges pinched together until the butyl cools.
Adding to the existing rubber butyl works great in my experience, especially if you ever have to go back into the headlight. Silicone would need to be peeled off again.
If anyone doesn't have all the stuff it takes or doesn't want to source/buy all the stuff, going to JnC is def worth it.
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
jmaxima03
Sep 27, 2015 10:22 AM
