Clearing driver history
Old Feb 3, 2014 | 12:04 PM
gsims's Avatar
I just got my 06 TL, and i recall reading a post on here recommending another new owner to clear the driver history. What is the procedure for that and should it be done? What is the benefit?
Old Feb 3, 2014 | 12:07 PM
^dunno wtf you're talking about.
butt, if you want to clear anything...disconnect the negative terminal from the battery for like 2-10 secs.
or, if you're talking about the driver's phone book, why not play with all the options inside the car.
a brand new car to you should be like christmas, and you should spend some time inside the car playing with all the settings.
Old Feb 3, 2014 | 12:08 PM
paperboy42190's Avatar
OP is right, clear the navigation history. this does not get reset by disconnecting the battery
Old Feb 3, 2014 | 12:13 PM
so, then go through all the in car settings to clear.
its not so hard
Nick216's Avatar
The Boss
From the title I thought u wanted to like erase an accident off your record. lmfao
Old Feb 3, 2014 | 12:20 PM
I forgot how exactly to clear everything manually(history and address), but an easy way is to access the diagnostic menu, and select the Hawaii map. It will attempt to load it, and when its unsuccessful it will return to CONUS map and everything will be reset to factory setting and all history gone.
I found that out by accident one time
Old Feb 3, 2014 | 12:22 PM
OP should get to know his car, like we all have done
Old Feb 3, 2014 | 12:26 PM
also dont forget to clear your HFL contacts too, otherwise the new owner will be calling all your friends and family lol
Old Feb 3, 2014 | 01:32 PM
Will Y.'s Avatar
Registered but harmless
Congrats on the car.
The HFL can store only a limited number of phone numbers, so you may want to clear those if you need the space or the stored number's IDs sound similar to yours. The Navi keeps a record of 50 or so prior destinations-- newest ones will replace the oldest ones at that point.
The HFL will direct you with audible prompts once you say "setup," IIRC.
The Navi info can be cleared and/or amended (for owner info) using the "Setup" button below the screen.
The procedures are described in the Owner's Manual and Navi Manual. If you didn't get the hard manuals with the car, they are available on-line at: http://owners.acura.com/vehicles/warranty .
Welcome to AZ.
Old Feb 3, 2014 | 01:34 PM
Will Y. to save the day, yet again.
Old Feb 3, 2014 | 03:03 PM
gsims's Avatar
Nice, Thanks everyone. Trust me, I am reading the manuals and learning all the features. Loving the car.
Old Feb 3, 2014 | 03:13 PM
gsims's Avatar
I will say i could have sworn before I got the car I read a post on here where someone mentioned this and listed steps like turning the key on with the accelerator pedal on the floor, then shutting it off and some other stuff. Does that ring any bells or am I thinking of something else, or just nuts?
Old Feb 3, 2014 | 03:17 PM
GKinColo08TL's Avatar
Are you talking about clearing the ECU, driver tendencies are stored by the ECU, or so I'm told. There are a couple threads on how to reset your ECU.
Old Feb 3, 2014 | 03:18 PM
^that's to reset throttle position/ECU, as our ECU is self learning and will learn your driving pattern/habit.
but a simple pull of the negative terminal on the battery will take care of anything that needs to be reset.the throttle and ecu will reset just by taking off the negative terminal for a few seconds.
for your "non-issues" you'll just have to be like EVERY one else before and after you, and play with settings in your car.
Old Feb 3, 2014 | 03:32 PM
gsims's Avatar
Got it, Thanks.
Old Feb 3, 2014 | 04:47 PM
kyle06's Avatar
Does resetting the ecu work well on a 6mt? I've tried to research it but couldn't really find anything on 6mt's.
Old Feb 3, 2014 | 05:03 PM
There doesn't seem to be a definitive answer. I would think it wouldn't because it supposedly stores how a guy drives and shifts the AT appropriately. But you can do the reset and try it, you can't hurt anything.
Old Feb 3, 2014 | 05:50 PM
like GkinColo mentioned, 6MT users can control when they want to shift.
the ECU doesnt have to learn our shifting patterns because we can override it at will.
Old Feb 3, 2014 | 08:38 PM
gsims's Avatar
That makes sense to me.
Old Feb 3, 2014 | 08:58 PM
bla8291's Avatar
I myself, just from playing around with the settings, have managed to erase everything from the previous owner except for the address book. I could delete them one by one, but for the amount of time that would take, I would rather do something else. If anyone knows how, that would be great,
Old Feb 4, 2014 | 08:18 AM
one by one it is.
Old Feb 5, 2014 | 08:43 AM
MarcoNorthPolo's Avatar
KCCO
While you're sitting there erasing the contacts you're sitting in your TL's driver seat though. It could be worse, you could be sitting in a dentist chair.
Aug 15, 2019 12:58 PM
Sep 17, 2015 09:01 PM
AZuser
Sep 17, 2015 10:15 AM
PortlandRL
Sep 14, 2015 12:01 PM
