Clear Protective Plastic on TL-S?
Old Jan 24, 2007 | 10:18 AM
jtconte's Avatar
When I washed my new TL-S I discovered clear plastic just in front of the rear wheel wells near the bottom edge. They are triangular in shape and about 6 inches long. Should they be there? Should they have been removed for delivery to me? Anyone else have these?
John
Old Jan 24, 2007 | 10:26 AM
juruki's Avatar
I think thats like a clear bra they put on from factory. Little rocks tend to hit that spot when ur driving.
Old Jan 24, 2007 | 01:21 PM
Christina72's Avatar
Does anybody know what that round circle is by the license plate (on bumper) of the TL'S?
Old Jan 24, 2007 | 01:35 PM
AdamNJ's Avatar
Make MyTL Great Again
or check the garage.
That's the location for the pull hook/tow hook for pulling the car our of something when it's stuck (not for towing). Along with your spare tire is what goes in that hole when you pop the cover off.
Old Jan 24, 2007 | 02:38 PM
So under the round circle is a bracket that will support an attachment to pull you? Along with spare tire? what does that mean?
Old Jan 24, 2007 | 03:39 PM
chill_dog's Avatar
Oderint dum metuant.
I just checked the garage, and I didn't see anything on the tow hook (which I found odd, so I probably just missed it)...my search was pointless as I obviously didn't use the best key words...sooooo, without being able to provide any useful back up to my answer (pics, technical info, etc.), here it is...yes, if you remove the cap there is a threaded hole that, I'm assuming, is in the frame. In the trunk where your spare tire is located there is a plug, threaded on one side, big round hole on the other. If you screw the plug into the hole, a tow truck driver can hook his wench onto the plug and pull your car up onto the truck.
Old Jan 25, 2007 | 12:35 PM
jtconte's Avatar
So, getting back to my question about the clear plastic- everyone leaves this on? All TL's come this way? Or is it just Type-S's?
Old Jan 25, 2007 | 12:41 PM
chill_dog's Avatar
I've never seen clear plastic on a new car (off the truck). Maybe your dealer had a paint protection package (similar to a clear bra) put on...could also just be the transportation protection and the dealer didn't remove it.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
hashbrown
Feb 18, 2022 11:20 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
